Ok guys, panicking a little here. 07 FJ 4x4 Auto, purchased in December with 30k miles, now I have 37k on it. No problems, nothing. Decided to change fluids.
Replaced fluid in rear diff, front diff, and transfer case with Mobil 1 LS 75w90. Went for a test drive around the neighborhood and guess what? After I shift into low, I can't get it into another gear. I can get it out of low, into the neutral spot, but then can't get it back into high or low. The gears just keep spinning and spinning. Tried twice and had to cut the engine both times to get it into gear.
Is this due to using Mobil 1 LS? Are the limited slip additives causing the transfer gears to continue spinning? HELP!!! Don't bash me, the Mobil one was one of only a few choices available that I could find (that or Royal Purple which I don't trust). I was in a hurry since the rear diff went swimming last weekend and I didn't want to wait for oil to ship to me.
Do I need to put something else in the transfer case? Is the oil in the transfer case the problem? Do I need to replace the rest of it too (will LS additives cause problems in the rear and front diff)?
AAARRRARAARGGHHHHHH SHHHHHHAAAAAATTTTTTTT!
Can't believe I wasted hours just to screw things up. Thanks for your help. BTW, I did search but couldn't find anything about LS or this problem.
