1 - 6 of 6 Posts
Ok I went to install my Optima yellow top but the cables are to short. what did you all do to fix this one? Then when I put the original back in the compass is all screwed up. Tried to calibrate it acording to the owners manual but no luck compass light is still flashing.
In regards to the compass, you need to select your zone and then drive in circles.
Depends on what you have the cables terminated with. If it is a screw on connection to the wire you can buy longer wire. If preterminiated/swedged on then you might have to buy longer cables.
- Solo
Once you remove the terminals, it resets everything, you have to recalibrate the compass as well as the clock on the dash.
1 - 6 of 6 Posts
