141 - 151 of 151 Posts
Ok, I have a few questions concerning the wiring.
I am installing a Garmin and want to mount it above the rearview mirror. I would like to tie the unit wiring right into the door lamp. Are any of the wiring for the door lamp accessory power on when key turned on? Which ones? Thanks
There are three lines that come from the dome light. One is the ground, one is hot all the time, and the last is powered on all the time until you open the door then it goes of for 30 sec. this is the control circuit for the door open light mode. If I was to add a GPS up there I would grab the power from in the drivers A pillar. There is a connector there with a red line that is powered all the time, there may also be a line, that is powered through the acc. I'd have to check the wiring diagram or test it to know for sure.
Discussion Starter · #143 ·
you are correct .. you could tap here (a-pillar):
however, another thought would be to continue the tap line down thru the dash, installing the correct amperage inline fuse (my GPS is 3 amps), and then connect into the fuse block.
by tapping into the a-pillar, you either use whatever fuse amperage is on that circuit (which could be too high for the GPS) or you add a fuse there which would be inconvienient.
Anyone in SoCal want to help out a fellow FJ owner?
Hey guys - Installer request here.
I just ordered the Acura console (looks identical to the Honda one above). It should be here in a few days.
I'm in Venice, CA - would anyone local be up for helping me out? I pay in whatever currency make you happiest ($, beer, pizza, :D). I'm ok with the cutting, etc. Just need help with the wiring and braket if needed to secure the unit.
Re: Anyone in SoCal want to help out a fellow FJ owner?
Sorry, I'm on the wrong coast. It's really not too hard to do, if you have some basic mechanical skills. Use a sharp blade if you decide to cut the headliner yourself.
Great job!
I like it alot!
Good taste! Same one I installed a while back. I managed to hit the crossbeam, no bracket needed. Love it. Good job. :clap:
Im so glad I finally found this thread, thanks Swiss!
swissarmy... Cool install, PMed you about brackets
not needed
