Two nights ago when I was driving home from work my engine started to shutter and lost almost all of its power. After a few seconds it went away, then came back, then went away. No check engines light.
Tonight on my way home it happened again. This time much worse. Felt like the entire front end was shaking and shuttering like crazy and there was all of the sudden no power. The check engine light and vsc, trac control, etc. all came on. I got off the freeway and pulled over. I turned it off and then back on and the lights went away and it ran smooth. Then when I was almost home it started again, and all the lights came on. So I stopped and restarted the engine. This time it ran smooth but the lights stayed on. I was able to scan gauge it and get P0306, cylinder 6 misfire.
First off, I do not know which cylinder #6 is?
About 1,000 miles ago I had the fuel injection service done at Toyota.
Over the weekend I washed the engine real good ( the same way I have many times in the past).
I have E3 spark plugs that have approx 18,000 miles on them.
Two weekends ago I cleaned the Throttle body and TBS.
I run premium fuel and drive like an old lady.
What do I do? Is this major?
I bought a spare plug so I have one here I can install. Is that the first step?
Did I jack something up when I cleaned the engine? Could water have gotten in somewhere?
What cylinder is #6?
Help! Thanks!!!!
Help! Thanks!!!!
