Your descriptions of the problem seem to be conflicting.
In post #1 you said "after 3 hours its take long time to start,its crank but not start".
In post # you said "in the morning the first start there is no issue".
I assume that the first start in the morning is after it has been sitting for at least 3 hours?
After sitting for several hours since it was running, if the engine doesn't crank and start almost instantly the first thing to suspect is that during the time the engine was shut off, fuel pressure in the fuel system was lost due to a leak somewhere.
The fuel pump is turned on only when the engine starts cranking, and it takes some amount of time to re-establish full fuel pressure if the pressure was lost because of a leak.
Since the problem seems to come and go with your attempts at cleaning the fuel injectors, the first place to look would be a leaking fuel injector.
What process was used to "clean" the fuel injectors? Were the injectors removed from the engine and individually cleaned with a commercial fuel injector cleaning machine, or was a fuel-injection system cleaning solvent added to the gas tank?
Yes I done cleaning with unplugged injectors and cleaned commercially.Again, does your FJ have the replaceable fine fuel filter in the engine bay, mounted on the drivers side fender liner?
If cleaning the injectors a 2nd time immediately resulted in elimination of the starting problem, but it returned again several days later, that's a strong indication that you have some type of contamination circulating in the fuel that is preventing an injector from fully closing, causing a bleed down of fuel pressure after the engine stops.
To get instant starting, there must be residual pressure in the fuel manifold after the engine stops.
You are correct there is some contamination in the fuel line, I again opened the fuel injectors an checked for leaking but nothing found after that I put the STP fuel system cleaner which we can buy here within the first drive itself the problem is solved..Again, does your FJ have the replaceable fine fuel filter in the engine bay, mounted on the drivers side fender liner?
