1 - 5 of 5 Posts
I have 2014 FJ, 70Kmiles, stock, no mods which I purchased in Jan 2018.
We've had a cold snap here with overnight lows getting down to 5-10degree(F) range (-15 to -12 C).
Twice in the last five days, my Check Engine & Trac Off lights have popped on when starting my FJ in the morning. The error has not appeared when overnight temps are in the 20's
My Ultragauge reads a P2443 error (Secondary Air Injection System Switching Valve Stuck Closed Bank 2) which I clear once the FJ reaches normal operating temp - apprx 186F.
I don't know what's up with the Trac Off light, but it also clears when I reset the CEL.
This P2443 error seems to be a big deal with the 5.7L Tundras, but I'm not seeing a heck of a lot of data about it on the FJ (though most of the FJ related complaints seem to be connected to aftermarket air intake mods).
The FJ is operating just fine, no rough idle, normal acceleration, etc. So, for now, I am inclined to "Keep Calm and Carry On" unless this error: a) keeps popping up or b) one of you good folks tells me "yeah, you need to address this."
I just had the exact same issue w/ my 2014 FJ w/ 84k miles...same P2443 code and Trac Off light....we had -17F temps when it happened...I also cleared the codes for now. Eager to gain some insights.
Same thing man. 2014 FJ 62000 KM. I cleared the codes two days ago and will update if it the CEL and TRAC OFF comes back. I searched online it's related to the air pump getting water inside but it's too expensive to replace. I will try to inspect the hoses underneath the right side of front wheel when I got time this Friday.
Thanks folks! Luckily we've only had two sub 10 degree days here since I posted the issue....but the error codes did pop up on both occasions. What really has me scratching my head is we've had plenty of 12-15degree days and no issue! You would think that below freezing is, well, below freezing and the codes would always come on if it's a water in the valve issue.
I'm wondering if this valve has some kind of bimetallic thermostat on it and the accuracy of the thermostat itself is falling off below 10? --But that's a wild guess.
Thanks again!
I too have the exact problem as you, though I haven't been able to clear out the code. I just had AutoZone read it today and got your same code. I'll be looking at the pump and associated working and hoses tomorrow to see if the dealer did something during my oil change and inspection. Thanks for any input.
1 - 5 of 5 Posts
