Hi, the 6MT models have a button that "cancels" the check for a pressed clutch wen attempting to start the engine. Well, I want to remove that check, like if the button is always pressed; in fact, the "clutch cancel" gets reset after the engine has started, so next time you have to press it again. I just want to be able to start the engine when I want, with no checks, all the time.
Any idea what I should do? There must be a wire that detects if the clutch is pressed, maybe if I short it?
