1 - 20 of 41 Posts
I know there have been quite a few threads on hooking up aux lights but I never found a difinitive one using OEM wireing.
I paid $195 (inc shipping) on ebay for the 520 FJ kit (part # is PIAA 5298) but subsequently decided I didn't like their wiring and I wanted to keep the wiring as stock as possible.
Using the lights by themselves not an issue, just on with the highbeams is good for me.
I then purchased the following from Matt @ TRDsource.com, he is considering selling these items as a package, if anyone has interest.
(1) Fog Light Switch PN: PT297-35070-SW
(1) Switch Harnes PN: PT297-35070-SH
(1) Lamp Harness PN: PT297-35070-LH
(1) AUX relay PN: PT297-89016
(1) 15 amp fuse
(2) t-taps
The switch was $40 ish, the harnesses & relay $70 ish.
I followed the install instructions attached below, but here is the photo step by step where I differed:-
First I replaced the OEM lamp connectors with the PIAA connectors.
I hacked off the lamp ends from the lamp harness with an exacto knife leaving the crimps and the grey thingy on each end. (no pix - but here's the firewall end)
It's a little tight trying to get the PIAA connectors off, the small flat screwdriver on a leatherman worked perfectly, pull hard too!
I yanked the existing PIAA wires out of the crimps then dovetailed both sets of crimps (I left the OEM ones on), soldered for good measure, and pulled up the aforementioned grey thingy.
Insert into connector with the green wire going into the flat side, the white w/black stripe wire on the side with the ridge. (discovered by trial & error - I popped a fuse when I originally wired the other way around)
Voila!
Everything else was done by the book (instructions), here are a few helpful pix
take all these bits off
stripped down
back of switch panel
T-Taps on
busniess end of switch harness connected (white connector, middle of pic with ground wire hanging out.
Ground wire (the 3 white w/black stripe wires lower left) was a real PITA, eventually I put electrical tape over the screw head and jammed it into the socket to ensure I wouldn't drop it.
I put my switch in position 6, just felt tider there.
For front end drilling and completed pix (I lost mine!) see these threads.
http://www.fjcruiserforums.com/foru...7861-piaa-headlights-installed-tons-pics.html
http://www.fjcruiserforums.com/forums/interior-exterior-visual-tech/24041-piaa-installed-bumper.html
Very nice, which wires green and green/white are attached to which corresponding wire on the harness purple or grey. One is switch backlight, the other is ground.
Hesitated myself at this question
there was nothing mentioned in the instructions so I trial and errored it again, connected purple to green wire t-tap and grey to white/green wire t-tap
Sorry it's not a very sceintific answer but everything worked so I went with it.
Forgive me if this has been answered already.
Question though. I'm about to buy the FJ switches for some fogs and driving lights. I've noticed that there are some blue pig tails (harness) already in the blank spots on the center console. Could you snip these off, plug them into the back of the new fj switch and then wire your piaa 520s up to those snipped wires?
That way you could use the rest of the piaa wiring, relays etc?
I guess you could do that, though I haven't tried, but why would you want to kill the factory wiring, when you can buy a harness for ~$15
If you used the factory switch and relay, and fuse in't the wiring harness behind the switch plate and terminates under hood where you could just use the plug to connect the lights or do your wire connections?
I believe the wireing behind switch position 1 (upper left) is for installing lights up on the roof, with the other end of the harness being somewhere in the drivers side A-pillar.
Do a search, I'm sure you'll find it.
Someone else jump in I thought the wires for the roof lights were on the left side lower plugs near the steering wheel and lower dash . Anyone know for sure as the plug under hood would be real easy to reach and wire?:thinkerg:
Discussion Starter · #12 ·
Discussion Starter · #13 ·
Sorry, haven't been to this thread in a while - just noticed I never answered your question.
The plug under the hood does run through the firewall but has no wireing/harness inside the cabin, that's why you need to buy the Switch Harness for the interior AND the Lamp Harness, which runs from the aforementioned plug-under-the-hood to the lights (the ends of which I replaced)
The wireing behind switch position 1 (upper left) IS for installing lights up on the roof, with the other end of the harness being somewhere in the drivers side A-pillar.
Hope this clears it all up.
I am new to all of this. Where do I find the wire harness in the hood compartment. Is this harness connected to a fuse panel and does it go near the switch panel. The connector in the panel is labeled optional off road lamp switch, can I hook an OEM switch up to this connector.
Wow. Intirely to much trouble just to use the factory harness, but great install nothingless. Only thing i don't likeis the amount of wire taps needed to use the "factory" harness. Not as plug and play as one would hope for.
nice write up. thank you
Discussion Starter · #17 ·
Harness in the hood compartment is taped under a major electrical wireing at the back of the bay on the drivers side
remove tape and plug
this harness goes via fuse panel but you need to plug in the relay. Cabin connector is on left side of drivers footwell
Unfortunatly you have to buy the switch harness to route to the switch panel because for some unknown reason the wireing for roof lights is there (behind top left switch blank) but wireing for front lights in not??!! (Unless '08s are different)
Great threads on this forum. I couldn't find a post that will help me do the following.
Is there a way to have the PIAA's turn on without having to turn on the high beams?
I am using the OEM switch and OEM Harnesses (interior/Exterior).
I also did the OEM rooflight switch and I noticed that you do not need the high beams on but maybe,again, it is Toyota's config.
Thanks in advance for anyone who can chime in.
Cheers,
mmmmm I saw the yellow plugs that are terminated just behind bumper on each side near headlights.....
anyone know what those might be. I thought they might be the plugs for factory lights.
anyone know?
1 - 20 of 41 Posts
