1 - 15 of 15 Posts
Howdy! I have 2 PIAA lights mounted up on my metaltech tube bumper. They came with a PIAA wiring harness that has a relay and a simple on/off switch.
I have this 5 point switch-https://www.amazon.com/gp/product/B01MSIYAHK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I want to cut off the PIAA harness switch and wire it up to the new sasquatch 5 point switch.
I've read a few things but I'm still lost. I know that I'll want to connect it to the fuse box so it's only on when it's on ACC w/ the key in.
What I don't know is "how to connect it to the fuse box"? Some say add a fuse? Which one?
Also ..."which PIAA switch wires go to which CH4x4 wires?"
This thread looks right but I'm not sure? Please help! Thanks.
https://www.fjcruiserforums.com/forums/lighting/536466-need-help-wiring-push-button-light-switch-fro-lid-light-bar.html
You will need to refer to the wiring diagram that came with the CH4x4 switch. I included the AOB instructions just for discussion and reference, but you will need to refer to the wire diagram that came with the switch. Based on the AOB diagram:
- Green/yellow wire to power from the relay harness.
- Red/yellow wire to relay activation connection.
- Blue/yellow wire to the FJ fuse interior fuse panel using the micro add-a-fuse (see picture). Find an empty slot that is activated when the key is in the on position, otherwise the light will remain on all the time. Alternatively you could wire to the interior dimmer light switch wire.
- Black wire to ground or relay ground wire.
Hope this helps.
Thanks! I did exactly that the first time through and it was still always on or off, even without the key in the ignition.
Not sure what else to do.
You probably have it plugged into a fuse that's always hot. Find a fuse that is only on when the ignition is on.
Here's the fuse box picture to help you determine which slot to use.
Thanks! I had it plugged into the bottom row, far right which should just be ACC?
What value fuse do I need in the add a fuse thing?
The far right should be blank (no connection/fuse). As for fuse, that connection should just power the LED light in the switch so 5 amp should be sufficient.
Discussion Starter #9
Thanks.Yes, exactly, that is blank on the bottom far right and from everything I've researched it is only on when the key is set to "ACC".
But I swear up & down I had it wired in there and it was always on? I'm so lost.
Just cuz I am feeling extra dumb right now I am going to ask this.
So if I wired up my switch as mentioned above, put a 5 amp fuse into the add-a-fuse and slotted it into the bottom far right it should all work as expected?
Or would I just put it in the far right slot with no fuse?
Yes use the 5 amp fuse. The add-a-switch will not output power without the fuse. Or you can try other available slots.
Discussion Starter #11
I'm still stuck on this. Argh. I can get it to be always on but I cannot have it tied into my ACC. What am I doing wrong?
Discussion Starter #12
Here is the latest.
Good news-The switch works. But kinda.......too often. Ha.
With no keys in ignition the switch is not backlit but I can press the button, lights will turn on and switch will light up.
Keys in ACC, switch becomes backlit, if I press the button the lights turn and switch will fully light up.
I was hoping that by having the add a fuse in the 2nd spot from bottom right which on the fuse box guide is marked "ACC" that the lights could only go on when I had the keys in the "ACC" position.
I think the issue is that I have the green wire from the switch going to the positive on my battery. So even if the key is or is not in ACC, it always has a direct connection to power. Is the switch just supposed to work this way and I am dense?
Here is how I have it wired up:
Switch Green Wire----Red wire to positive on battery
Switch Red Wire 1--To lights
Switch Red Wire 2--To add a fuse
Switch Black Wire-Ground
The ones I have are wired like this. Instead of battery, use a switch power source, and if you still use the relay, connect it to the light output, from switch, then run power from relay to lights. Lights will be backlit when power is on, and fully light, when switch is flipped on.
1117456
thanks but my switch doesnt look like that and I have no idea what you're saying.
Here is the latest.
I am not a wiring guru, but in my opinion you will need another relay. This relay would be triggered by an add-a-fuse connected to an ACC On slot in the FJ fuse panel. Let's call this relay 1 and the existing relay 2.
Keep your existing connections, add a second relay, and change the following. Power from the battery goes into Relay 1 pin 30. Relay 1 pin 87 connects to Relay 2 pin 30. The ACC On add-a-fuse connects to Relay 1 pin 86 to trigger Relay 1 "on".
Again I am not an electrical expert, so evaluate and use at your own discretion/risk.
FYI I like to be able to turn on aux lights with the FJ off. I can use the lights to setup at night without having a key in the ignition.
1 - 15 of 15 Posts
