1961 - 1980 of 2019 Posts
cliffy, you're rig looks pretty awesome with those mounted! What size of tire, and what is offset on those rims? Looks mean!
Sent from my NiPhone using Tapatalk
Sorry for late reply, I just read you're post.
Thanks, They 33x12.50's on 17x9 -12mm with 1.5" spacers
I wanted a -25mm wheel so I could lose the spacers but they are rare and expensive in 17". This stance without spacers would probably take about a neg -48mm though.
Just finished getting these on. Next will be the Toytec 3" lift and 5100 Bilsteins.
Fuel Beast 17x9's -12mm offset and Nitto Ridge Grappler 285/70/17's
I do get rubbing at near full lock. If the lift doesn't fix it, I will be doing a BMC.
16x8 Eagle Alloy 186 (-11 Offset, 4" Backspacing). With these specs there is roughly 1.5mm of clearance from the front caliper to the rim.:nerd. Rims came on a set of Wrangler Authorities in 235/85r16. Tires are bit noisy (light hum at highway speeds) but otherwise monsters in the snow and mud so far.
Thanks!
Andrew
Cooper ST Maxx 295 / 70 / r17 on Black Stealth Custom Series Ray 10 17s. I've got a Icon Stage 5 Lift with Icon UCAs and an aggressive BMC. No rubbing so far.
4-Corners Moderator
Just some pictures of FJs with big tires!
I personally think it would be super cool to do a solid axle build where they keep it looking more stock so it could still be daily driven reasonably and run only like 37s but it could still dominate the trails.
FN Wheels fX pro bronzet... decals by importEquipment
Details:
FN Wheels ƒ(x) Pro
Diameter: 17"
Width: 8"
Offset: 0mm
Backspacing: 4.5"
Load rating: 955KG (2,100lbs+)
Weight: 24lbs (approximate) (vs. 27lbs + for the OE wheel)
Certification: JWL-T, VIA, SAE J-2530, DOT approved
Colors: Matte gunmetal, dark gloss gunmetal, matte black and matte bronze
Toyota specifics: 106mm hub centric for Toyota hubs, lug holes drilled for 12mm Toyota wheel studs for a snug fit, and center machined to accept flat snap-in OE center cap* (not the raised OE Pro cap).
website info = https://www.tacomaworld.com/threads/fn-fx-pro-wheels-show-thread-and-info-all-models.414804/
Tires:
Nitto Ridge Grappler 285/75/17 (load C) = roughly 34x11.5"
