1 - 5 of 5 Posts
I bought a factory power inverter from a 2013 fj thinking all were wired for it. I popped the blank out to put the receptacle in and there was no plugin there. Aren’t all fj wired for all options wether the option is there or not? I’ve got an o7. Thanks for any input.
No, only A-Trac (if you have diff lock) and sub-woofer are pre-wired. You need to find a scrapped FJ and get the switch and all cabling to go with your inverter. Big job.
Isn’t the incinometer a plug and play as well? I think you just need to drill a hole and run the wire to a pre existing plug. I’ve been meaning to find a used inclinometer for a while now..
Cruise control on early FJ's is prewired and so are the power mirrors if you don't have them
I tried to follow the plug and the wire harness for my 2008 FJ . But it is integrated the the mean power harnesses.
1 - 5 of 5 Posts
