1 - 7 of 7 Posts
We're heading out to see Guy Clark in Aspen tonight from northern CO, thinking the windows not opening won't be a problem, then there was a threat of a fart latter on and well, now we need to know...t:rocker::rocker: he power windows are not working whether or not the button is locked, does anyone know where the fuse is? We read the fuse panels under the hood and in the truck under the dash and didn't see anything labeled.
Sweeeeeet, thanks, we're about an hour out of Glenwood Springs, we'll check those fuses when we get there. Thanks again for looking that up as I don't have a manual with me.
Luckily, no farts yet, just some diesel fumes and burning brake smoke.
:clap:
I checked all those fuses and none of those are blown. Any other suggestions. Mine stopped working today. I started truck and turned on AC then went to roll up windows and they weren't working. I did check AC fuse too.
G'day,
Have you checked to make sure you have not locked the windows from the switch ?
might be an easy fix, to press the button and unlock em.... just saying
cheers
Baz
:blueblob:
1 - 7 of 7 Posts
