1 - 7 of 7 Posts
hopefully this is in right section.
i have a 2nd gen prerunner tacoma 4x2. i want to see if it possible to remove front parts off an fj and bolt onto my tacoma. it'll be a manual t-case im assuming. want to know if this is possible and if it'll be bolt on. i asked someone on a tacoma forum and they said fj front is bolt on, just want to confirm.
I have done a bunch of research in this as I had a 2wd tacoma that I wanted to convert to a 4wd.
For any Tacoma 05 and newer the front end is the same as the 06+ FJC You can swap back and forth parts. but you must have the 6lug axles for this to work. You had stated prerunner which means 6 lug in the taco world, but I just want to make sure you don't have a 5 lug taco.
What does not work is the rear drive shaft has to be changed out because of length difference with the transfer case.
so it does work? i have 2nd gen tacoma 6 lug... going to look for parts and maybe a year or two have everything ready to swap out.
1 - 7 of 7 Posts
