1 - 4 of 4 Posts
hey folks
I tried to search the forums but couldn't come up with what I need, I have few questions about pro comp's 3" lift kit
they stated that its 3" front and 3" rear, I think in this case the FJ won't look front and rear equal clearance "I mean the rear would look lifted more"
if you already installed your 3" pro comp lift kit, may you post your FJs pic? :D
thanks
When I had this lift installed in my truck, the front was lifted closer to 4", and the rear 3". I did end up having to install a diff drop to bring the CV angles a little closer to acceptable. The truck was leveled nicely.
weve installed several...once the lift is on, it levels the vehicle. most lifts are designed to do that, since it sits lower in the front, and your looking at a 3" lift, realisticlly, it is closer to 4 in the front, but it is conciderd a true 3" lift
thats cool ;)
it sounds like i'd have no problem "rubbing/body mount chop" with either 285/75/16 or 305/70/16 right? even when I have trd wheels which are 16x7.5?
what do you think?
pics of lift installed are welcome :D
1 - 4 of 4 Posts
