1 - 1 of 1 Posts
hey all,
So I picked up a set of Pro Comp 8179's and a set of the Pro Comp rock rings to mount on them. I will be mounting to them a set of used 285/75/17 Hankook MT's, probably at a local Discount Tire. My question is this:
Does it matter whether or not the rock rings are mounted prior to having the tires mounted? I can see wanting to have all the weight present to get the balancing right, but I could also see not needing to since the weight will be consistent all the way around the rim. Also, the other reason I'm leaning towards not adding them is I think they will interfere with the mounting process.
Thoughts?
1 - 1 of 1 Posts
