1 - 2 of 2 Posts
anybody know what all is included for part #00012-M0781-01
its listed as the drop hitch kit for FJ cruiser?
When I bought my hitch (OEM) it included the hitch, 6 bolts and the replacement plastic panel for the bumper (has small notch molded in to fit around hitch. You will also need to wire the trailer lights. You can get a less expensive converter box and wire into your lighting or buy the Toyota converter which even though it cost a little more has all the parts to use the factory wiring. There is a small box that plugs in above the drivers footwell, a relay and fuse that plug into the engine fuse box and a short 4 pin trailer cable with a bracket that attaches to the rear bumper and plugs into an existing plug on the rear frame. No cuts, no splices just 2 bolts and plug-n-play. directions are included with both kits.
1 - 2 of 2 Posts
