My new 2011 FJ needs that second horn. Toyota confirmed that the parts (Horn Assembly 86510-60240 and Bolt 90080-11545) were "compatible" with the 2011 FJ, so I bought them.
Having read the posts on this installation on this forum, it appears that there are some wiring changes on the '11. The location of the second horn wire must have moved, because there's nothing interesting looking on the right side near the fender.
There are some interesting looking plugs, one is attached to the sheet metal RIGHT NEXT TO THE PRIMARY (weak) HORN with two wires: white and white/black. The primary horn has only one wire, that is gray. Photos below. There is also a suspicious-looking plug along the left side, also shown in a photo, with two wires: white and green/red. Neither of these has a plug that would connect directly to the horn, so I'm doubting that they are the second horn wires.
My questions is obvious: where is the secondary horn wire on the '11?
If I can't figure this out with advice from the forum, I'm going to surrender and have the dealer install the horn.
Thanks,
Chris
Thanks,
Chris
