To read the original full thread and post questions/comments on this topic, please go to http://www.fjcruiserforums.com/foru...ical/106757-how-install-backup-lights-kc.html
How to Install Backup Lights (KC)
This install will show you how I installed KC Backup lights on my FJ. I used KC brand lights, but this would be a very similar install for any other brand.
Part 1 – Relay Installation
Tools/Materials
KC Relay harness from box
16 gauge wire
Butt splices
Ring Terminal (Yellow) – large enough to fit a 10mm bolt.
Crimping tool
Wire Cutter
Wire Stripper
Electric tape
Heat Gun
Dremmel Stylus or a Small Drill
1/8 drill bit
Wire snake
Plastic Panel Remover
Philips Screw Driver
From the contents of the box I used the Relay Harness and the included #10 sheet metal mounting screw (not in the pic)
In the “trunk” I removed the access panel for the emergency bottle jack and removed the jack and tools. The bolt on the right, attaching the jack bracket would be a good place to make a ground connection.
The Ring terminal on the black wire (ground) for the relay harness was too small, I cut if off and connected a larger Ring terminal to fit the 10mm bolt.
The green wire you connect to the battery (provides power to the lights once the relay is energized) already had the fuse and the ring terminal attached. There is no way to fit this through the firewall. I uncoiled the wire and laid it on the ground along the FJ to decide where to cut the wire near the fuse holder. I needed enough wire to run it from the battery under the hood and through the firewall and additionally run the wire from the back of the FJ to the front kick panel, near the driver’s seat.
With the green wire cut, I moved on to the white wire (provides power to relay, turns on your lights). I want my rear light to be powered by a switch (if you want your back up lights to turn on without a switch, during backing up, you could tap into the rear wire harness located in the rear jack compartment) so I needed to attach more wire so I can run the white wire to the front of the FJ with the green wire. I attached more 16 gauge white wire with a butt splice and measured it out to the same length of the green wire attached to the relay.
It is time to start fishing the green and white wires. Pull straight up on the two panels over the door sills to expose the wire run.
Grab your plastic panel remover, if you use a screwdriver to pry, you could damage something.
Shove the panel remover between the plastic panel (in the rear passenger section) and the weather stripping. Pull the panel remover towards yourself, do this from the bottom and up 2 feet, a few clips will pop loose. There is very little room, but enough that you can now slide your wire snake from the jack compartment forward until you can pull it out of the crack. You can see the wire snake in the pic.
Tie your wires to the snake with electrical tape, very tightly. Then gently pull them through to the front of the FJ.
The green and white wires are successfully pulled through. Pull the wires all the way through, but leave enough in the rear to mount the relay. Remove the tape and the snake.
Open the plastic clips in the wire run and add your green and white wires.
The green and white wires are fully installed in the wire run.
Get your drill, time to mount the relay. I used a Dremel Stylus, it fits great in small places. Attach the 1/8 drill bit.
I drilled a 1/8 hole and screwed the relay to the FJ in the jack compartment. I chose that location as you can place your hand through the hole and feel where the screw will come out. I don’t like to drill when I don’t know what is behind. Now you can see (above relay) the jack mount bolt is removed, take your black wire with the ring terminal and place the bolt back into the hole. The relay is grounded.
Now under the hood.
Grab the green wire attached to the fuse holder and ring terminal. Remove the fuse from the fuse holder and remove the 10mm nut from the positive battery connector. Then install the ring terminal on the green wire. Replace the nut.
The other end of the green wire needs to get run through the firewall. There are 2 places you can use, empty plastic plug near the top of the pic or the large plug with the factory wires running through it at the bottom of the pic. As you can see the plug on top I have is filled, so I am going to use the one below it. You need to place a hole through the plastic plug, I used a screw driver to make the hole, need to push hard to get through, make sure you are not going to hit any other wires on the other side.
You need to remove the kick panel on the driver’s side. Grab the top of the dead pedal and pull it toward you.
Unscrew the plastic nut, then grab the plastic kick panel that is to the left of the nut and pull it towards you.
From the inside of the driver side foot well looking up and toward the front of the FJ, you can see the other side of the screw driver. I removed the screw driver and used the drill with the 1/8 bit and widened the hole in the plastic plug.
I pulled the green wire through from under the hood to inside the FJ. The green wire entered near the red wire in the pic, the pic highlighted the end of the green wire in my hand vs where it entered. There is a sleeve over this side of the plug, once you push the green wire though, you need to stick your hand under the sleeve and grab the green wire, you won’t see it.
Connect the green wire you just pulled through with the end of the green wire that is in the factory wire run from earlier. I used a heat shrink – waterproof butt splice, I heated it with a heat gun after crimping. Since this is sitting on the floor next to the door, it could get wet somehow, even though it will be under the floor. Tuck the wire under the floor to the left.
Next Part 2 - Lights Install
Tools/Materials
16 gauge wire
Butt splices
Crimping tool
Wire Cutter
Wire Stripper
Electric tape
Heat Gun
1/8 drill bit
Wire snake
Now under the hood.
