I think you're missing Sparky's point.
The radio, and the wiring carrying B+ to the radio, should be protected by a fuse at or very near the origin of the B+ supply. One option is to install an 'Add-a-circuit' adapter to one of the multiple unused positions in the cabin fuse panel near your left knee. That way, you can select at appropriate fuse rating to protect the radio from any kind of internal short circuit, as well as protect the B+ wiring to the radio.
The fuse in the radio connector will NOT prevent a short in the wiring to the radio from burning up the wiring unless there is another fuse 'upstream' of the radio connector.
If there IS another fuse upstream of the radio connector, then the fuse in the connector is redundant, and should either be eliminated, or replaced by a higher amperage fuse so it is never the first to blow in case of any failure. It's much more logical to replace a fuse in the fuse panel than to tear the dashboard apart, isn't it?
Additionally, what caused the radio fuse to blow in the first place?
