The Raptor tune on my 08 is the best thing I did for my FJ it runs fantastic and has daily for years now with no other engine mods ,exhaust work etc ,Using a pedal commander with it is even better ,I could never go back to the stock tune.
I'm surprised on a gasoline tune that your FJ can handle an E40 blend. I would think that at WOT near redline you'd get CEL's or other issues.40% E85 to 60% 91 PON will yeild 95 Octane PON which is about E40, and no CEL.
So long story short is that your tune is specifically for ethanol blended fuels only? I do not understand how a single tune can handle both a 40% ethanol blended fuel and 100% gasoline fuel yet not have an ethanol content sensor somewhere in the fuel system with a flex fuel tune. How can the computer be smart enough to know what is in the tank?I think you already answered a lot of your own questions....
Hi,Hello! Been following here and there for about a year.
I have a 2007 6MT FJ in NA. Getting it re-geared as I am just carrying too many people out to the boonies for good mountain performance going into BC and thought about tuning as well.
I wanted to know how exactly we are extracting more torque with a tune. What parameters are we taking advantage of that Toyota could not? How many km have people put on with this tune? My truck is at 215 000 and its a 4x4 so it isn't new but I'd still like to hit 350 or 400k with it.
I'll dispute that... I have a MT and it's got noticeably more power and torque throughout the range.Hi,
The Raptor tune mainly adjusts where the automatic transmission shifts gears. This is what most posters have commented on.
As I've understood it, you'll get little benefit using it with a Manual Transmission.
Norm
The Powergate 3+ hooks USB to your PC to download the tune files from Raptor. The PG uploads the tune to your FJ via the ODBii port.Sorry if this has been answered and I’m sure it has. But this thread is 56 pages long now lol.
I have a 2012 FJ with 39k miles. I looked in the raptor website and it said the SC will take the truck from:
200kw = 280hp approx
To
310kw = 415hp approx
are those the real numbers. I’m not seeing anyone else talk about them?
secondly how much is this SC and other than the SC what else do I actually need?
Thirdly, is this still for sale and if so how much?
lastly. What is the power gate people are talking about?
cheers
I'm unaware of anybody on here that actually has the Raptor SC. We all just have their mild tune. My bit of advice is to buy a kit from the US instead. Magnuson gets my vote by a landslide. A stock Magnuson supplies 6 psi. Raptor supplies 7 psi. Therefore both kits will have about the same power level. From 280 to 425 crank horsepower level seems accurate enough but maybe a little high. Keep in mind stock dyno numbers are around 190 hp to the tires.Sorry if this has been answered and I’m sure it has. But this thread is 56 pages long now lol.
To
cheers
Thanks I was confused and i'm assuming this tune is far cheaper than the Raptor SC or the Magnuson one. How much is this tune do you know?@LukeD are you actually asking about the SC or the Raptor Tune which is what this thread is about?
If you want details about the tune then visit the abridged version here with just the tech stuff in it:
Raptor ECU Flash.The tech bits only
[MODERATOR NOTE: This is an abridged copy of the Raptor ECU thread with just the most relevant technical points for those wanting quick reference. For comment: Continue to post replies in the original post: https://www.fjcruiserforums.com/threads/raptor-ecu-flash.732214/page-53#post-9325109]...www.fjcruiserforums.com
What is a gearing tune?hmm does this has any negative interactions with a gearing tune do you know?
Ethanol is less volatile than gasoline. In a colder climate it doesn't want to vaporize so it's harder to ignite when cold. Trucks that run it use block heaters so they can start. Lean is not the problem for me. I'm running extra advance and need the less volatile fuel. Because I don't have an E85 kit or injectors I'm only modifying my gasoline slightly. The real down side with Ethanol is that it destabilizes after 2 days in the tank and separates from the gasoline so I have to use it right away. Good and bad. I found a better solution (see new post).I'm surprised on a gasoline tune that your FJ can handle an E40 blend. I would think that at WOT near redline you'd get CEL's or other issues.
For background on my 91/93 octane gasoline tuned Supra I accidently ran a 93 oct E30 blend. The power is awesome on a boosted application and on the street it ran fine, but at the track I was running into issues with the computer going into limp mode to save itself from either going too lean or reducing knock. Took me awhile to wrap my head around why an ethanol blend is not good on my non-flex fuel sensored "gasoline tuned" Supra and the gas station I went to did not have E content listed. I know for a fact the Supra fuel pump can handle the flow rate that even E50 demands so the issue was my current tune was not designed to run on ethanol.
How does a warm climate help your situation? Doesn't colder air reduce detonation that can be caused by running lean, which is the most likely scenario to happen in your case?
