Anyone think the RC6 puts extreme angles on your CV's? If so, is has anyone tried to drop the front diff a little lower? Then the Front driveshaft angle increases. Problems, problems.
I would suggest that you measure the angle of 3" lifts and the RC lift, as all the 3" lifts I have seen have a far less severe angle compared to the pics of the C lifts I have seen.
Not to mention a higher center of gravity with the same ground clearance as a good set of adjustable coilovers. IMO I like the look of the 6, plus you can run a couple inches bigger tires, but unless you go straight front axle, it doesn't make much wheelin sence.
I've driven both on road OME, FOX, and a ProComp 6" kit--
Both OME and Fox lack a front swaybar(On my setups,) and I will tell you that the 6" was uncomfortably unstable, whereas the two 3" kits demonstrated acceptably-stock handling.
Chewy, i think this is a very interesting thread especially after reading tons of posts about CV failure. I was thinking of adding a 2-inch spacer (way later)over my 6 inch, which is not going to happen with stock CV.
Ok maybe this is insane, but couldn't a vendor or some specialist make some sort of better CV boots, since i dont really want to spend on an SAS and new lifts....??
Ideas chewy?
Thanks
Abdul
As I remember correctly Terry mentioned that All Pro Off Road would not be developing more IFS goodies since the SAS kit is completed. I'm fairly certain the beefier axles were in the running for inevitable production.
Edit: I also recall reading that there are currently beefier CV axles readily available for the 4Runner.
i am not well versed in this area but from what I've read before, the main problem is limiting droop, so a quick way to ease your worries are limiting straps and I've also heard of sliding CV axels...but I don't think any are available for the FJ yet...
The CV angle on the RC kit is alot higher than the two other 6" kits (procomp and fabtech) but I would think RC did their best to design in the most diff drop with out cutting the cross member. I mean they know the biggest worry is CV failure and that the success of their product depends on the lowest CV angle possible. I'm sure if you want it any lower youd have to cut the cross member. But who wants a big ass snow plow of a cross member at the front of their FJ (no offence to those who went with procomp or fabtech)
I haven't had any problems yet, and actually my only beef with the RC kit is the stinkin squeeky ass rear upper arms...some zerk fittings on those would be nice...I've hinted this over and over but I don't think RC is goin to take the hint...I'm probably goin to buy the extendable allpro upper arms and hope they don't hit the gas tank...
My advice is don't worry your self crazy over it, replacing a CV isn't to utterly expensive, and you put the 6" lift on knowing it could possible cause problems...and from some of the pictures I've seen, alot of the 3" kits have higher CV angles than ours anyway
Oh another idea I had was getting the adjustable coilovers from radflo, and dialing it down to the lowest lift possible in the front that would prevent rubbing (say 4.5" to 5" of lift instead of a full 6)...that would greatly reduce the CV angle..just another idea
I actually want the RadFlo shocks and put it on the highest setting, that dang Fab Fours bumper weighed the front down so much. But I don't know if im going to keep the Fj considering it only gets 11-13 mpgs, and its my daily driver. When I first lifted it to the 6inches, gas was 2.15 here now its 3.39
Yeah, the rc6 is pretty extreme This is mine on a jack, so this is what they'd look like several times while on your average trail. But so far, I haven't had any issues. And I beat it up pretty good.
