1 - 6 of 6 Posts
As it seems I have finally found a FJ manual transmission, with the "Convenience" package, I would like to make sure, before I go to the dealer:
- all MT have read diff lock right?
- it is a 2008 model, is it still possible to do the ATRAC hack?
Thank you
Alessio
I went on the Toyota web site (Toyota.com) and the information now states that the rear locking differential is optional on the MT. This is different than in the past.
Make sure you purchase your FJ with a rear locking differential. For ATRAC to function the ECU requires the vehicle to be equipped with rear locking differential.
Wierd, here in Canada (toyoata.ca)it still shows that the locking rear diff is a standard feature on the base model with 6MT but optional on the Auto trans.
No ATRAC hack required for late '08 and on (and some very limited number of '07s that came off the end of the '07 production run).
If you have lockers you have ATRAC and they will both work together in later models.
And just to echo what the rest are saying, MT does not guarantee rear locker, make sure it is part of the package.
The description of a vehicle I am interested in contains:
Full-time 4x4 System, Torsen Center
Differential with Locking Feature
Does this mean it has a rear diff lock? There is no other occurrence of the word "diff" in the description.
Thank you
Alessio
Um... doesn't look like it. That description just means you're able to lock the center diff on the 6 MT. You need to find some description that says "rear differential lock" or something like that.
1 - 6 of 6 Posts
