1 - 1 of 1 Posts
SOLD it in 15 minutes...Ready Welder II
Battery Powered Portable MIG Welder
Model #10000
Brand New in Sealed Box.
Ordered new at summit from Metal Tech
$475 + Shipping
Great for Extreme Off Road Repairs.
Link to Ready Welder Specifications
Factory Description:
10250 The RWII Model #10250 is the most powerful, affordable, portable, and versatile MIG welder in the world! It is cabled similarly to other spool guns as the primary intention is to use this model as a spool gun attachment to the welding machines which already have a built-in ground wire or clamp. The Model #10250 also comes with the AC to DC Power Converter for welding with CC (constant current) stick machines. It will connect to all DC output welders as well as batteries. This model is primarily used by welders wanting a spool gun attachment to their engine drives, MIG machines and stick machines. The Model #10250 has a one year 100pct parts and labor limited factory warranty. Comes with Ready Welder II Case which includes: -RWII high-impact MIG gun -Twenty foot power leads -One spool of flux core wire -Extra tips and gas hose fitting -Ten extra feet of gas hose -Foam lined molded briefcase -AC/DC power supply to drive gun controls when connected to a CC power source Process: -MIG Features: -Cabled as a spool gun attachment for all DC output welders -Welds Steel, Stainless, Aluminum, and other Metals -Can Connect to Batteries: -18 Volt Battery Can do Thin Sheet Metal -24 Volt will Single Pass 1/2 @ 275 amp -36 Volt will Weld up to 3/4 @ 350 to 400 amp -Welds 22 Gage to 3/4 Material Ground Cable Not Supplied -Can Connect to other MIG/Constant Voltage, Stick/Constant Current Welding Machines -AC to DC Power Converter to Drive Gun Controls When Connected to CC/Stick Machines -Uses Wire Sizes from .023 to .045 Without Changing Rollers -Uses Heavy-Duty Tweco Quality Front End Consumables -Wire Speeds of 50 Inches to 900 Inches per Minute -Battery Polarity Indicator Lights -Twenty Foot Power Leads (Expandable 100ft) with Quick Disconnects -Built-in Gas Valve -Grounding Clamp Attached -Dimensions: 18'' H X 24'' W X 8'' D -Net Weight: 19 lbs Warranty: -One year 100pct parts and labor limited factory warranty
1 - 1 of 1 Posts
