install it yourself, many (including myself) have added rear auxilary 12V outlets as well as power invertors. just read up and get the appropriate gauge wiring.
I put in a 400w inverter and outlets in the center console and the rear left side and have been very happy with it. Read about it here: http://www.fjcruiserforums.com/forums/stereo-electronics/16823-400w-inverter-installation.htmlI just picked up a new 2008 FJ for my business and have enjoyed every moment. However I didn't realize it when I bought it but its missing a rear power outlet like some models have. Is it possible to have it installed by either the dealer or myself? The parts guy says he doesn't have any packages that would help.
Yes, it should. But it may require you to be in PARK, with the engine running to generate at the 400 vs. 100 watt level. Either way, the OEM inverter is setup to run only while the engine is running, unlike the aftermarket ones.I know for a fact the factory 400w inverter will run a 32"lcd and a ps3.:rocker:
Did you ever find this?Does anybody know the part # for the power outlet button??? I got the number for the socket but need the button that turns it on
