This has been a very helpfull little big book over the years. Many application's or examples can be changed to fit your application's. (Example) adding a air compressor or aux lights even converting a positive output to a negative output. Using a relay will let you use any switch you like. OEM swithes to control your aux lighting or anything else you may want to add, thanks for the reply's. Please post any examples you may have.
