1 - 7 of 7 Posts
Replaced my pulleys years ago.......I remember when turning the tensioner pulley to loosen belt there is a small hole that you can slip a small screwdriver in to keep the tensioner pulley locked with no tension. Where is that damn hole please.
1119036
Oh, but there IS one and exactly for that. :whistle:
Are you for sure that small hole can handle all this force and pressure when replacing the Belt ?
I believe the easiest and only way
For turning the tensioner pulley to loosen or replacing the belt will be by the 14mm socket..
I just didn’t that way,,
Oh, I meant this is the hole for securing the tensioner pulley in the "loose belt" position with an allen wrench or something similar.
There really isn't that much tension on the belt. I used a small allen wrench in that hole to hold it in the loose position.
1 - 7 of 7 Posts
