1 - 7 of 7 Posts
It should fit just fine since it looks just like the ARB locker switch that I am going to replace.
Your Rigid lights should come with instructions and wiring diagram, your gong to want to follow the instructions. It would be good to know the basics of an DC electrical circuit and switching.... There is no need for embarrassment, that is for those that do not ask any questions and break or burn up things. Do not rush your install, use the correct tools, parts and pieces. The instal is not hard but the quality of the install is important for long term success..... If you have never done anything mechanical or electrical you should find someone that has "experience" to help/teach you.
It will fit, but you will have to trim a little bit of plastic from the sides of the blank space. I've used the daystar switch for a couple lights on my FJ.
Thanks for the replies guys! I am actually getting the work done at a local shop, but I'm going to see if I can observe so I can get the general idea. Had the FJ for a little over a year now and have decided to dip my toes into the modding pool with something like this before I do anything major. Thanks again
1 - 7 of 7 Posts
