1 - 5 of 5 Posts
I have installed a new LED bar on top of my fj cruiser.
Every time the speed gets to 60 miles/hour you start hearing whistling and vibrations.
I checked all my nuts and bolts but still no result.
Any advice?
2007 FJC 4x4.
Usually you can just add some door-edge guard (found at any parts store) on a couple fins and it will stop all noise.
My newer single row bar ended up being further from the body of the truck so I got some black corrugated plastic (which is used on roof ridge venting) and cut it to shape...crammed it between some fins...100% silent
Reactions: Irving Zisman
The door trim is where its at. I have heard that if you put a strip on the upper, middle, and lower cooling fins, it will silence your lightbar. I got very lucky with mine as it makes no noise at all.
1 - 5 of 5 Posts
