1 - 10 of 10 Posts
Yes there are. Call the dealer for the plastic pieces or ask the forum to see if anyone still have them after they added racks.
The bolts are too long to seal up the holes. You could always put a little silicone around the covers to make sure they are sealed.
There is a bracket with 2 10mm bolts that have special washers to keep out water.
Don't drive very far without the covers on. I made this mistake when I bought my roof rack from another forum member. I took the covers/brackets off the night before the 4.5 hour drive and it whistled non-stop. I had a very bad headache by the time I got there.
The bolts to fill the holes without a roof rack are shorter than the bolts that hold on the roof rack.You also need rubber backed sealing washers,I think they come in a kit from Toyota.The white plastic pieces are for asthetic purposes,to make it all look better.I used sealing washers from Ace hardware when I installed my used roof rack with some black RTV to be safe.Hope this helps.
reason why I want to take off is, company is moving to new ground where we get low parking places in the basement.
thanks so far
1 - 10 of 10 Posts
