1 - 4 of 4 Posts
Hey,
Hope someone can give me some good pointers here.. I have an 08 FJ, my set up is, 285/70/17, 3" Bilstein lift and SPC/LR UCAs... the thing is I installed some 1.5" wheel spacers two days ago, and now my tires are rubbing at the body mount. Its rubbing on the drivers side and only when I turn the wheel completely to the left..
I've never done the BMC because never needed to, and I'm really trying to avoid it so, since I have this aftermarket UCAs, I was wondering if I could adjust the caster to move the tire forward right there on the UCAs or if I should do it on the lower side.. I really don't know as much to know what to do.. so if somebody could help, I would very much appreciate it.
I'll give my 2 cents. First off your Bilsteins are only providing roughly 2.5 inches of lift. I have the same setup as you. Bilsteins, 285/70/17's, 1.5 inch spacers and JBA upper control arms. I have added a .25 inch spacer on the driver side strut to level the vehicle. My very first project was the body mount chop and without it I would suffer tire rubbing as you are.
It might be possible to adjust your alignment and lessen the amount of tire rubbing but I recommend that you simply accept the fact that a BMC is necessary. It's not as difficult as it sounds.
Ugh!!! Im really trying to avoid that! I'll take it to an old school aligment shop tomorrow, to give it a last check and see if theres something that can be done, maybe by adjusting the caster thru the UCAs if not, I'll just go ahead and BMC the damn thing.
There is a thread here were it does outline how to run 285's with out a BMC - it was al through the alignment. I'll see If I can dig it up.
1 - 4 of 4 Posts
