Sounds like you have decent protection so far.
Here's a few more items to look for:
e-locker skid (All-Pro)
Slider's that stick out past your body and have rear kickouts (All-Pro)
- This is important so you can pivot around some of the rocks and keep them off your sides
- Since this trip, the stock Toyota slider's were swapped out for All-Pro's sliders.
Take your time and ensure that you have a spotter with you that's really good and also walk the obstacles yourself all the way till you find a safe place to stop. You will be required to stack rocks to climb some of the obstacles. Ensure you put the rocks back where you found them after you've used them. (this is common trail etiquette in any backyard.)
You will be at first a little freaked out by all the metal scraping and banging. You'll soon start to learn which part of your Toyota is making what sound.
Keep a slow but steady momentum through the trail. Stopping at each bump or rock makes it more difficult for stock gearing to climb over the simplest of obstacles. (this is why it's a good idea to pick your line and walk the obstacles).
If you're not on a time schedule take three days to do it so you can enjoy the experience and take your time. First time can be mentally and physically gruelling.
You're
required to have:
- Spill Kit
- Porta Potty with bags to pack out your poop.
- Garbage bags
Ensure you're camping at designated camp locations (IE: loon lake, Rubicon springs) If you can't make it this far you can camp on the trail but be sure not to venture more than (if I can remember correctly) 10ft off trail otherwise you can get a ticket.
If you see someone approaching in your rear view, find a good place to pull over and let them pass.
This is the only rear tight section that may dent the rear section of the FJ. Take your time through here, stack rocks under the driver's rear if needed to lessen the angle that the FJ is tipping into the pinch rock.
Take care on Cadillac Hill as it can be a bit of a challenge depending on conditions.
Bring lots of water!
Other than that enjoy the experience! Great views up there.
