1 - 3 of 3 Posts
I've got a stock FJ with some interior mods, whats settings should I change and what to?
engine size to 4.0 liters and tank size to 19 gallons. Im pretty sure those are the main ones to change.
That is correct. There are no settings you need to "change" - the Scangauge is not affected by modifications to the vehicle, as it just reads data coming from the main ECU. It is designed as a monitoring tool, not a programmer or performance add-on... You must set up the Scangauge with the engine size, fuel type, and fuel tank size to get accurate fuel-related readings, but all other changes are for your personal preferences.
1 - 3 of 3 Posts
