Do you have a write up on these rear passenger grabs? They look great.
A scangauge will display the charge/discharge amperage and voltage of the aux battery? And control the relay that ties it to the main? I doubt that!I installed a scangauge II.. In the OBDII port... kinda does the same thing only easier and better.. ..i think..
I don't have a write up but they are really easy to instal. I purchased them from a NOLA company called ExtremePara.com. They ship everywhere and will custom make them to your specifications. To install you just pop the caps on the overhead door latch and instal the loops under the bolts one at a time. tighten up and you are good to go.Do you have a write up on these rear passenger grabs? They look great.
Yes the early model TT has this type of shift nobs. However the designer of those obviously did not live in a cold climate, because they are really cold in winter
Oh.... Never mind... :grin pretty close though..A scangauge will display the charge/discharge amperage and voltage of the aux battery? And control the relay that ties it to the main? I doubt that!
What is that overhead console you are running?Here are a few, I have a ton more.
Billet Stuff, feels good to the touch and looks cool as well!
Actually, it feels cool all the time too!
Plus an AL Box in the back, one of the FJ's issues is lack of storage- problem solved!!…..gm
AJAY,The AL storage, where did you purchase that? Or did you fab it yourself?
