Status
Not open for further replies.
1 - 1 of 1 Posts
Wanderlust
Discussion Starter #1 (Edited by Moderator)
To read the original full thread and post questions/comments on this topic, please go tocomplete skid plates comparison
Or click the following link to go to the NEW open thread for discussion as the original and this one are closed: The NEW Complete Skid Plate Comparison & Listing Thread
Last updated on 23 April 2017 by FJX2000
Below are all the currently available skid plates and under armor protection for the Toyota FJ Cruisers. Please check with vendors for latest pricing and availability if in doubt.
All-Pro Offroad
Skid Plate Options, Price, & Weight:
Front IFS Skid Plate - $269 - 54 lbs
Transmission Skid Plate - $99 - 12 lbs
Transfer Case Skid Plate - $389 - 42 lbs
Lower Link Front Mount Skids - $129 - 7 lbs
Lower Link Rear Mount Skids - $99 - 5 lbs
Construction: Steel (Aluminum Available for Front IFS Skid Plate +$90)
Finish: Black powdercoat available (Standard on Link Mount Skids, +$30 for Transmission Skid, +$50 each for Front and Transfer Case Skids)
Notes: Transmission Skid requires Front IFS Skid Plate
ARB
Skid Plate Options & Price:
Front & Transmission Skid Plates - $435
Rock Slider Skids - $143.12
Construction: Pressed and Folded 3mm Steel
Finish: ???
Notes: Skid plates also compatible with 2010+ Toyota 4Runners and Toyota Prado 120 & 150 Series. The rock slider skids mount to the bottom side of ARB's rock sliders (part #4420100 ).
ASFIR 4x4
Front Skid (07 - 09) - $244.02
Front Skid (10 - 14) - $291.03
Gear Skid (07 - 09) - $132.60
Gear Skid (10 - 14) - $129.60
Fuel/Transfer Skid - $374.70
Exhaust Skid - $126.70
Rear Diff skid - $173.55
Construction: 1/4" 5052 aluminum
Finish: ???
Notes: Unsure on the skid plate finish or weights and their website is pretty confusing as there are random compatibility dates thrown around (like 06-09, 10-11, 06-12, 11-12, etc.) so I just tried to make my best guess as to what they really meant. Since they are out of the US their shipping rates are pretty high as well.
Boz Tec
Rear Diff Skid Plate - $386 - ??? lbs
Construction: "Built from 1/4" steel, welded inside and out with a 3/4" steel cradle. Two saddle connections are form fitted to the axle tubes, secured with 1/2" U bolts and protect the axle housing out to the spring buckets providing optimal coverage of the rear differential and e-locker as well."
Finish: primer powder coat
Notes: For FJ, Tacoma, or 4Runners
BudBuilt
Front Skid - $289 - 31 lbs
Mid Skid - $249 - 45 lbs
T-Case Skid - $229 - 43 lbs
Crossmember - $149 - 15 lbs
4-Piece Combo (All 4 Above in Regular or Light Options) - $725
Gas Tank Skid - $239 - 45 lbs
Beefy Gas Tank Skid - $379 - 62 lbs
5-Piece Combo (4-Piece combo + gas tank skid) - $900
5-Piece Combo w/ Beefy Gas Tank Skid (In regular or Lite Options) - $1,050
Rear Diff Skid - $298 ($50 discount if purchased with combo) - 22 lbs
Front Skid for Rough Country 6" Lifts - $300 - 31 lbs
Mid Skid for Rough Country 6" Lifts - $300 - 45 lbs
Stock Bumper Filler Plate - $140 - 25 lbs
ARB Bumper Filler Plate - $150 - 25 lbs
Warrior Bumper Filler Plate - $150 - 25 lbs
Expedition One Bumper Filler Plate - $170 - 25 lbs
Construction: Steel 3/16", Light Steel 1/8", Aluminum 1/4", Stainless Steel 3/16"
Finish: Unfinished, Powdercoat (any color) on 4-Piece Combo +$293, Powdercoat (any color) on 5-Piece Combo +$346, Powdercoat (any color) on 5-Piece Combo w/ Beefy Gas Skid +$384
Notes: Many, many options to choose from. I suggest checking out the website.
FJ Toyman Off Road
Skid Options & Price:
Rear Shock Lower Mount Skids - $125 ($150 for King Shock Guards)
Bolt Bumpers - $17.50
Construction: Steel skids and bolt bumpers are 316 stainless steel
Finish: Powdercoated (Metallic Blue only option on King Shock Skids)
Icon Vehicle Dynamics
Skid Options, Price, weight, build, finish:
Lower Control Arm Skids - $173.20 - 15 lbs - 3/16" laser cut steel - powdercoated black
Rear Lower Shock Mount Shin Guard - $131.20 - 5 lbs - 12 Gauge 304 Stainless Steel - unfinished
Outpost Offroad (OPOR) - No Website
Skid Options, Price, Weight:
Lower Link Front Mount Skid - $69.96 - ??? lbs
Construction: 3/16" steel
Finish: unfinished
RCI Off Road
Front Skid Plate - $220 - 35 lbs (steel) or 18 lbs (aluminum)
Transmission Skid Plate - $165 - 28 lbs (steel) or 14 lbs (aluminum)
Transfer Case Skid Plate - $235 - 33 lbs (steel) or 22 lbs (aluminum)
Fuel Tank Skid Plate - $195 - 30 lbs (steel) or 20 lbs (aluminum)
Lower Control Arm Skids - $115 - 16 lbs (steel) or 8 lbs (aluminum)
Rear Differential Skid - $295 - 18 lbs (steel)
Lower Link Front Skids - $130 - 8 lbs (steel)
2010+ OEM Bumper Filler Plate - $65 - 4 lbs (steel)
TRD Integration Plate - $200 - 10 lbs (aluminum)
Construction: 3/16" Steel or 1/4" 5052 Aluminum
Finish: Unfinished or Black Satin Powdercoat
Notes: Filler Plate for OEM Bumper only for 2010+ FJs and the TRD Integration Plate is basically a Transmission Skid Plate but cut in such a way so owners can utilize their TRD skid plate like what came on the Trail Teams Ultimate Edition or TRD Pro vehicles.
Ricochet Off-Road
Heavy Duty Front Bash Plate & Engine Skid - $389
Transmission Skid Plate - $129
Transfer Case Skid Plate - $109
Fuel Tank Skid Plate - $249
Lower Control Arm Skids - $129
Cross Member - $99
Cat Tube Rock Blocks - $29
Combo w/ Everything Above + Free Gift - $995
Expedition One Bumper Filler Plate - $60
ARB Bumper Filler Plate - $99
Rear Bumper Skid Plate - $99
Construction: 1/4" 5052 H-32 Aluminum
Finish: Natural Aluminum Finish or Anodized Black, Red, Blue, Orange, Gold, Gun Metal, or Natural Brushed
Notes: Anodization can be done to all skid plates or when in a combo kit can be selected for only the front bash plate and lower control arm skids or all skids.
ShrockWorks
Skid Options, Price, & Weight:
Engine Skid - $309 - 42 lbs
Transmission Skid Plate - $299 - 28 lbs
Transfer Case Skid Plate - $279 - 29 lbs
Fuel Tank Skid Plate - $349 - 56 lbs
Cross Member - $50 - ??? lbs
Package of 5 - $1,161 (bare) or $1,321 (black powder coat)
Finish: bare steel or black powder coat
Notes: $75 in savings when 5-piece combo package is purchased
Skid Mark 4x4
Hitch Skid Plate - $154.95 - 16 lbs
Construction: 1/4" Steel
Finish: unpainted or powdercoated red or black (+$10)
Notes: Fits in 2x2" hitch receivers.
Total Chaos
OEM Lower Control Arm Skids - $131.30
Long Travel LCA +2" Skids - $117.64
Long Travel LCA +3.5" Skids - $117.64
Lower Link Front Mount Skids - $105.03
Construction: Steel
Finish: Unfinished
Notes: Long Travel lower control arm +2" and +3.5" skids only compatible with Total Chaos long travel LCAs. Lower Link Mount Skids only compatible with OEM or Total Chaos lower links.
Toyota/TRD
Front TRD Skid Plate - $275
Construction: 1/4" Aluminum
Finish: Powdercoated Silver
Notes: Only compatible with 2010+ FJ Cruisers. Integrated TRD logo. See RCI Off Road Skid Plates for compatible skid plate system that integrates this TRD skid plate
Trail-Gear
Skid Options, Price, & Construction:
Front Bumper Skid - $109.43 - 3/16" Steel
Transfer Case Skid - $219.96 - 3/16" Steel and 1.5" .120 steel tubing
Rear Diff Skid - $43.11 - 1/4" A36 Steel
Finish: Unfinished
Notes: Front bumper skid only works on Trail-Gear Front Bumpers but is designed to fit with the addition of Line-X or Rhino Liner bed liners. Rear Diff skid requires being welded on.
Trailworx Fabrication - No Website
Lower Link Front Mount Armor - $175
Construction: Steel
Finish: Unfinished
Notes:
1 - 1 of 1 Posts
Status
