1 - 20 of 53 Posts
I've got about 900 miles on the cruiser...She is a blast to drive and so much fun off road...i've only tried one super easy trail because I am very new to off-roading.
So lately I've noticed a weird clunk/thud when i get off the brake and gas it from a red light. I feels like either the car is shifting really hard into gear or that it was in the wrong gear and is doing a very quick downshift to get to the correct gear.
I tried searching for this issue in this forum but didn't come up with anything similar.
I know it's not the brake vibration/pedal pulse that the vehicle makes when braking...I also know it's not the sudden surge that sometimes occurs when the vehicle is at a complete stop. I experience both those things and stop worrying about it after reading similar posts in this forum.
But this clunk/thud I feel when I get off the brake and on the gas from a red light is worrying me...and it's new...just started happening two days go.
Anyone have an idea as to what's going on?
Thanks!
Discussion Starter · #2 ·
Forgot to add that I'm not giving it a lot of gas after the light turns green...I've barely started to let the car roll and I'll hear the clunk/thud.
It seems to happen almost immediately after I take my foot off the brake and the vehicle starts to roll.
There's also some play in the slip yoke that causes binding as well. The harder I step on the brake coming to a stop, the worse the problem is when stepping on the gas. I consider this normal.
DEWFPO
Yes...I have also noticed that the harder i step on the brake coming to a stop the harder the clunk/thud is...
Boy am i relieved that this is a "normal" thing.
Mine is an MT, and I don't hear any clunk so for.
But I used to have the same problem on my Infiniti G35 Coupe. Whenever I downshift to accelerate or get off from a dead stop, I heard a clunk from the rear. Then I found out it was a rear axle problem. There was even a TSB for the G35 Coupe, it stated that the Wheel bearings were not tightened/torqued properly.
Is it from the front or from the rear? Do you hear clicking sound when backing up on an incline? It could be the bearings or just some normal noise. Best way to find out is take it back to the dealer and have them take a look at it.
No, I have it too in my SE TRD AT. It's felt specifically in the pedal. Kind of like a slight metalic click in the pedal, like something is busted in there. It doesn't happen every time though. I drove a manual, and didn't notice it at all. As long as it's normal, I'm ok with it ;)
make sure if you have recently used your tire jack or stuck something in one of those area, might be something rollin in there:bandit:
been here before. and spent lots of money just to find out it was something rolling around
· Banned
I'll tell you exactly what it is (mine's done it since it was new).
These beefy brake caliper pistons tend to "stick" just a bit and release fully once the rotor barely begins to move. That's why, the harder you brake, the harder the clunk tends to be.
I don't know if the shoes tend to be a little sticky, or it's the nature of the heavy dual piston caliper.
PS: If your slip yoke clunks EVER...you better lube it pretty good.
I have had this on mine since new. I havn't paid much attention to it but it does seem to be continuous & uniformed in when & how it happens. It doesn't seem to get any louder.
I have dismissed this as a "operating as normal" condition. I will pay more attention to it & repost my .2 here.
Discussion Starter · #15 ·
i don't think the clunk is a result of brake pistons sticking...my last car had some massive oem brembo 4 pots up front and i never felt them stick...
the feeling i get through the brake pedal feels more like a tranny thud/clunk than a brake piston unsticking...although this is purely my opinion.
· Banned
Well, I thought mine was a good theory...to convince me it's normal operation!
I tried to make mine do it today, and it didn't. Fairly warm, humid day here in NYC.
It may be tranny related, but I bet it's the brain...it's always the brain!
Same thing here. Feels like the electronic tranny forgets to shift back into 1rst sometimes and instead of shifting while the tranny is spinning, it clunks into gear at a complete stop. I don't think this should be good for the long term on a tranny but what do I know? All I can say about that is that the "electronically controlled transmision" on this truck scares me a bit. Why did they need to put complicated electronics? They were doing just fine as is. As far as the surge, I've felt that also, I have a feeling it's from the a/c compressor cycling on and off.
· Banned
I notice something like this when I brake heard, then let off the brake the car kinda shakes forward, almost like someone hit me from behind very very lightly. It's only when I press the brakes down hard, then wait for a bit, then let off of them.
Its the rear drive shaft or propeller shaft (toyota calls it). mine started doing it so I crawled under and started looking around and tugging on the drive line looking for something loose. I saw that toyota had grease fittings on the parts where there should be (not to common anymore) so I decided to give them a few shots of grease. Now its more quiet than when it was new.
1 - 20 of 53 Posts
