1 - 4 of 4 Posts
My set up is OME heavies on all corners with 17x9 ProComp 9005 with 4.75 backspacing. I am also currently running 305/65/17 Xterrians. But I was wondering if I could fit 33x13.5x17's? I know I might have to get a body mount chop. But will it clear the UCAs? Are there any other issues I need to know?
Thanks for the info. :)
i just put on my 33x13.5x18's and i have rubbing. I had to get spacers to clear the shocks or im guessing they are called UCA's. But I will have to get a chop because the rubbing is real bad. After im done with the chop i will let you know how the ride is.
you will probably hit the stock UCA's. You also might hit the sway bar when you are close to full lock with the suspension drooped.
1 - 4 of 4 Posts
