1 - 16 of 16 Posts
SOLD!!!!
[/B]
I have an extra OEM Air Dam Hella light wire harness, Part # PT297-35072-RW (Off Road Roof Wire). This is the wire harness that connects the two Hella lights in the OEM Air Dam.
It is the Hella harness found in this thread - http://www.fjcruiserforums.com/forums/interior-exterior-visual-tech/71460-found-part-numbers-factory-air-dam-wiring-harness.html
I'm located in Colorado. I paid just over $115 for it from my dealership. Willing to ship for FREE. Paypal excepted and preferred. Please contact me with any questions.
Discussion Starter #2
Bump...Anyone?
Last bump, then Ebay...
this is the outside harness that plugs into the roof plug receptacle?
I have non-OEM Hella lights - can you show me the connector ends of the plugs? Interested!!
Hope these pics help.
Discussion Starter #6 (Edited)
Still available.
Steve -
Help me understand this whole OEM Off-Road Harness thing. Inside the A-Pillar is a 6-Pin Male Connector. What does that 6-Pin connect to? It looks to me like (based on your pictures/post) that there's another harness that fits between the 6-Pin and PT297-35072-RW. Am I correct? If so, do you know that part number?
Here's my gig. Putting 4-100 Watts on the roof. Wanted to go stock wiring switches, relays. I'm using the AUX wiring for the center 2 lights - by using the stock config, they'll only light when the high-beams are on, but I'm fine with that. Basically, I'm running a power and ground wire from the AUX plug found in the engine bay back up the A-Pillar to feed the center 2 lights.
So then I get to running the outer 2 lights with the stock off-road wire setup. Get to the A-Pillar, and there's a 6-Pin connector with 5 wires for the Off-Roads. Well, that was a shock. Figured that the power harness for the off-roads would be similar to the plug I found in the engine bay for the AUX lights. Course not. So now I either need the mystery part that goes from the 6-Pin connector down to the Power/Ground, or I need someone to help me disect what each of the 5 wires connected to the 6-Pin connector do.
Can you help??
Still available...Who wants it?
Discussion Starter #9
Still have it if someone wants or needs it. I'll even lower the price to $75!
Hey I am interested, do you have the part number for the rest of the kit; relay, in cabin harness, switch etc?
Discussion Starter #11
Still for sale. Only $60 and I will ship for free.
Still for sale?
Does anyone have the wire harness part number to go from the this "Y" harness on the roof (shown above) to the A piller connector located behind the trim (left A pillar0?
Hi did you ever get your issue resolved. I am trying to do the same thing. I need the wire that goes from the connector mounted on the A piller to the roof. I wan to use the stock swith and relay (I already installed those) and different roof off road lights on my Gobi rack. I noticed in picture the 2 pin (black and green wires) at the end of the roof light harness. Why are there 5 wires on the A pillar connection? If you know what to do with that connector (A pillar) I would appreciate your info. Thanks.
2007 FJ Cruiser
Did anyone ever figure out the mystery section of wiring harness? I'm trying to do the same thing right now and can't find it anywhere. thanks.
1 - 16 of 16 Posts
