1 - 4 of 4 Posts
Just mounted up some Fierce Attitude M/T tires on my stock TRD wheels (2010 TT). They look awesome, and perform great in mud/dirt. However, they do rub slightly at full lock, pushing into the UCA just a bit.
Any suggestions for spacer size, and if not - tips for figuring out spacer size?
TIA!
My wife has the exact tire & wheel and had the same problem. The spacers will fix the UCA rub but will create another...body mount rub. We went with 1 1/4" Spidertrax spacers and then had the body mounts chopped. Zero issues now.
Another option is to go with an aftermarket UCA to avoid spacers and the chop.
Thanks! Should have mentioned, body mounts are already chopped, so that _hopefully_ shouldn't be an issue. Will look at the 1 1/4" Spidertrax...
May be doing some suspension work on the FJ later this year, so maybe will look into spacers / different setup on the UCA at that time.
TIA!
i got Spidertrax spacers for my nitto tires too,, and they r good now..
1 - 4 of 4 Posts
