1 - 3 of 3 Posts
Error code shows speed sensor, and all abs, vs. Lights, etc. Are on. Replaced LF wheel speed sensor, fixed nothing, could it be one of the wires going out of the sensor and back up top? All of this started after 3" suspension lift was installed. Thanks in advance!!
The wire is more than likely the problem. When working on the suspension due to lazinesss most techs don't remove the wire for the ABS and let the heavy suspension components hang on the tiny ABS wires and they end up breaking.
Admin
If you don't see the wire broken completely in 2 you will be able to run your hand along the wire (most likely the wire in the back to one of the rear wheels) and feel a skinny part of the wire... that will be where the wire inside the insulation is broken.
Don't feel bad... I did the same thing. I said to my learned friend that we should disconnect the sensors as I had heard the wires break easy... he said it looked like there was enough slack. Nope! LOL.
He helped me solder the wire back together though, so no big deal.
Those wires are TINY.
1 - 3 of 3 Posts
