Thanks for the link. That guy measured just about everything but what's really important. I can't find where he measured from the bottom of the wheel to the underside of the fender, which is the best way to compare heights from rig to rig.
Here's my current measurements, from lower wheel (closest to the ground) to the underside of the fender:
Left Front = 31"
Right Front - 31.4"
Left Rear = 32.8"
Right Rear = 33"
That's with the OME heavy setup. The average height difference between my front and rear is about 1.7" My inclinometer is a few degrees nose down. I want to make it level, and would like 3" of lift up front.
How long have you had your lift (i.e. have you crawled over a lot of rocks and up/down very steep trails)? Your front might settle after awhile. I've had mine on for about 11K miles. Maybe I've settled more than you because my ARB bumper and Warn 9000 is heavier than your setup.
I don't know that I agree with your assessment of the "whats important measurement". In my eyes, whats important is creating ground clearance and room for articulation. Knowing the relative change from stock to post-lift is what is important in my eyes. Regardless...
Yes, I have wheeled mine quite a bit, over what most consider to be "most difficult" trails (see these pic
thread 1 and
thread 2 as an example) with 10k miles on it after lift installed, 9k after bumper/winch installed. Measured mine with the measurement you are looking for and came up with:
Front (L) - 30.5", (R) - 31"
Rear (L) - 32.75", (R) - 33"
These were done in the dark just to give you my reference points and my gas tank is pretty empty and I have 16" wheels which would make a difference also. As you can see in my sig, I run the "med" OME springs with Demello bumper/Warn M8k winch.
When I compare points on the thread I provided, I'm running just under a 3" lift from most reference points. I'm very happy with the way my OME kit performs and the ride quality. Sorry to hear that you aren't happy with yours...
