1 - 20 of 406 Posts
Looking at the Stoptech/TRD big brake kit and thought to myself 2 things
1. its really really expensive
2. its only .1 inch oversized, not really a big brake kit imho
I know that size was chosen because of the oem 16 in. wheels, I dont really care, i wanted something that was going to be a bigger upgrade.
After doing some research and looking on the forums I was looking into making my own BBK using all Centric components (StopTechs parent company).
This consisted of Stoptech cross drilled rotors and Centric Posi-Quiet calipers designed for the Lexus GX470/4 Runner Sport v-8. These come preloaded with pads. Refer to pics for part numbers.
Additionally, I also got the larger OEM dust shields from the dealership (55$ each) for that model. Not necessary but i thought it was a nice touch.
To my surprise everything bolted on, no hickups whatsoever the alignment was dead center, the new dust shields even bolted on no problem.
The only thing i had to do was bend the brake line ever so slightly and i do mean slightly. The alignment was very very close to the original.
OEM is 319 MM, TRD is 323(?), this is 338mm...
Overall I am happy with the results.
Summit racing/Jegs/JCwhitney all sell these parts, wait till there is a coupon code to get an additional discount if you are trying to save some bucks.
Install is pretty straight forward,
1. remove wheel,
2. remove caliper (2 bolts +10mm nut for the brake line),
3. remove rotor,
4. pop off black dust cover,
5. remove cotter pin and remove aluminum retention ring,
6. remove axle hub nut (35mm socket, you can rent this socket for free at autozone w/ 20$ deposit)
7. remove hub (4 bolts),
8. remove old dust shield,
reinstall new parts
dont forget to bleed the brakes when complete
17 inch wheels or larger will be needed, double check you clearances before hitting the road
this cost me about 550 with the dustshields, you can save even more by skipping the dust shields and going with autozone/napa/oreillys parts and you may even be below 400$
Extreme Truck & Tow Carbon-Fiber Ceramic Brake Pads | Power Stop for those interested in getting the Powerstop rotors/pads (available now) and red powder coated calipers (ETA June 2016)
128.44127L and 128.44127R = rotors
142.44228 and 142.44227 = calipers
enjoy...
(pics in no particular order)
thanks for fixing the pics Baz
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Update:
Power Stop part #S2766
Here is the part number for the power stop red powder coated calipers, cost is around $260.
Dont forget, some of these sites have discount codes.
Very nice work. It almost looks like the dust shields are identical, though I am sure they are not. Could probably bend the OEM ones back a little if there was any interference and still run them.
Those do look VERY purdy!
The dust shields are definitely bigger. In the parts catalog the parts numbers are different for the sport (v8) and the non sport (v6), and specifically state for larger rotors/calipers, this part number also matches the Lexus GX470 part number, the Lexus was V8 only.
Besides the 2 reasons I mentioned in the original post I wanted to upgrade because stoptech basically hung up on me when I called and asked them about getting a big brake kit, "you gotta call TRD for that, click"
Well, no I don't....and neither do you
I did the same upgrade on my previous voodoo except I used 2005 Tundra V8 4x4 calipers and blanks. Its the same upgrade you did. If using FJ dust shields, there is some trimming required. Its a definite improvement over the stock FJ brakes. Its also a lot cheaper than the TRD big brake upgrade for the FJ. I also upgraded to ss brake lines then.
Great info and cool looking upgrade for definitely less money than trd. Thanks for shearing. Does that system works on both 16 nad 17 inch wheels?
Discussion Starter #10
According to autozone.com the 2005 tundra V8 has 319 MM rotors Part Number: 31267DG
Discussion Starter #11
16`s will not fit, OEM 17`s should fit, not sure though as im running 18`s
You are right. I did the upgrade on my voodoo with 13wg a few years back using 13wl calipers. The newer ones from the 08 gx470 are 13wh. I will upgrade to 13wh on my ttue when they wear.
Discussion Starter #16
The pads that come with the posi-quiet calipers are not designed as a high performance pad, as with any brake job, better pads=better performance
Go with whatever pads you like, EBC and Hawk have excellent options. This will maximize the benefits of any brake system.
Forum Beer Miester
Hey I can see some of the part numbers in the photos but would you mind editing your post to add the specific numbers? Sorry to be a bother but I just want to get the order right the first time.
I have always wanted a smaller brake package so I would be able to run a 15 in rim. In order to have more sidewall on my tires. I haven`t found such a system yet so i`m running 16 inch rims .:) I don`t want to run a tire bigger than 285 because it just kills the gas mileage
Going to do this next time my front brakes are due. I'm surprised upgrading brakes isn't more popular being that all the modified fjs out there have so much more weight added to them. My only concern is if the ratio between the front and rear brakes is still the same. Seems like if just the front are doing more work then the car might want to dive more when braking. Do you know if the rear are also bigger and if they would also bolt up?
1 - 20 of 406 Posts
