To read the original full thread and post questions/comments on this topic, please go to http://www.fjcruiserforums.com/forums/stereo-electronics/60452-brain-surgery.html
So i had a custom labeled CD get jammed up in the FJammer. Well, today i finally got around to pulling the old one out, and, i felt like taking it apart...
Step by step-ish:
After you pop the fascia off, you then pop the face plate off (there are tabs all around, just use a small flathead to lift them up..Its on there tight!)
Remove all the screws, and pop the silver plate off.
The black piece on top with the Toyota factory label on it has a hinge in the back, so it just lifts up after the silver plate is removed.
This is what happens to sticker-labels:
Gently remove the CD. REMEMBER, everything inside there is very brittle, so no man-strength is necessary.
Display the victim with honor.
Viola!
It never hurts to do-it-yourself.
Step by step-ish:
Viola!
