1 - 1 of 1 Posts
Ok so I got an infinity basslink 2 ...... I've seen a few guys running the original basslink on some old threads so I figured I'd give it a shot .......... I looked up the wiring for the factory plug and used it only for the hi-line stereo connects , wired an 8 guage ground , an 8 guage power wire direct to the battery and even bought the factory sub switch to use it as a remote wire ........... my problem is IT KEEPS SHUTTING OFF , it'll hit a couple times and shut down ...... I've tried turning the gain REALLY low and high, same thing with the bass boost ........ I've tried the low pass filter at almost every position possible ..........and same thing happen IT SHUTS RIGHT OFF AFTER A COUPLE SECONDS ........ I'm about to chuck this piece of $hit ............. Any Advice ?!?!?!?!
1 - 1 of 1 Posts
