1 - 7 of 7 Posts
With a wheel using no center cap, can you see the ring? reason i ask, i need a set, and a local shop has them in my size... but their red.
I don't think you will see the ring. Usually the inside of the hub is chamfered (notched) a bit which will hide the ring.
If you can see the ring, just paint them black.
It will depend on how thick they are and what design or type of wheel your running on to whether you will be able to see them.. Easiest cure is a coat of flat black paint.. couple of bucks, 15 minutes of your time...
Yes, you will see them.
This is exactly why I went with the chrome ones from All-Pro rather than the blue ones from Spidertraxx.
Whenever I take off one of my caps, I can see the spacer quite easily.
1 - 7 of 7 Posts
