1 - 20 of 260 Posts
Post here if you have a supercharger installed. TRD, URD, or other! Please post some of the following info if you can.
Vehicle Info: 2008 6MT (indicate manual or auto)
SC: TRD
Installation Miles: 15,000 (# of miles on vehicle at installation)
SC Miles: 41000 (# of miles on supercharger)
Current Miles: 56000 (2019)
CAI: aFe Stage 2 Si
Other options: TRD exhaust, UCON-EMS(to install), URD Walbro 255 LPH fuel pump(to install), URD 7th Injector(to install), URD SuperGrip pulley(to install)
(list other performance options like; pulleys, tuners, injectors, etc.)
Performance Info: None (if you have measured performance info, please post)
Issues/comments: No issues. (dropped mpg does not count as an issue :))
Pic:
Supercharger Maintenance
I've jotted down some info I found Googling around for a couple of hours. Please do not treat what I post here as gospel! Use as a reference only.
TRD Supercharger
The TRD supercharger(intercooled roots-type Eaton M90) is considered a sealed non-serviceable unit with a maintenance free service life of 100,000 miles. As such, your dealer will have no procedures to follow for doing regular maintenance, so you are on your own.
From what I've read, there are a few things you can do to help extend the life of your supercharger well beyond it's expected 100K life.
NEW: 06/02/2014
TRD S/C Maintenance How-To from the Tacoma World forums. This is a how-to for the nose drive oil change, impeller bearing re-grease, drive coupler replacement, and drive belt replacement.
1)Belt inspection/replacement
Make it a habit to inspect your SC belt and replace it when it's worn. I've read the expected life time of a SC belt is approximately 10K miles. It is recommended to always carry a replacement belt with you and know how to change it out. You never know when it will break. Also, worn/loose belts can slip, robbing boost.
Replacement SC belts:
TRD PTR30-35070 Dayco 5PK1790
Goodyear Poly-V Gatorback 4050705 5PK1790
Belt tools: (not required, but makes the job a little easier)
Serpentine Belt Tool Kit
DIY:
https://www.fjcruiserforums.com/forums/engine-performance/124868-how-supercharger-belt-change.html
2)Check your coolant reservoir fluid levels.
The coolant reservoir should look like this when working properly. Do not overfill the reservoir. You can check this by turning the key to on without starting the engine. Check for leaks if you have to keep topping it off.
Toyota Coolant, radiator and supercharger:
Toyota Super Long Life Coolant, #00272-SLLC2 (the pink stuff)
3)Check that your coolant reservoir pump is still working.
Check your reservoir pump on occasion to make sure it hasn't quit working. This check is done when you check your reservoir fluid levels and test the coolant flow.
Replacement pumps:
Johnson CM30P7-1 pump. Stronger, more reliable pump. Check eBay, ~$140
Ford Racing LIGHTNING Intercooler Pump. A direct replacement. Check eBay, ~$110
TRD Intercooler Pump part# PTR29-35062
4) Changing nose(snout) oil
The next thing you can do is change the nose oil out every 30,000 miles. The nose bearings will wear over time and start to shed metal. That metal gets into the oil and then makes it way into the main impeller bearings. This can cause the main impeller bearings to wear and now we are talking a SC rebuild($$). Changing the nose oil out every 30K will help keep that nasty metal away from the expensive impeller bearings. You will need 6 ounces of oil. The GM oil comes in 4oz tubes, so you will need 2 bottles.
SUPERCHARGER COUPLER SWAP KIT - ZZPerformance
GM SUPERCHARGER OIL - ZZPerformance
Rolling Performance - Specialize in M45, M62, M90 and M112 supercharger rebuild kits
5) Coupler replacement
The most common part to wear out first(besides the belt) is the coupler bearing. The holes in the coupler get worn and it sounds like rocks rattling around when at idle.
SuperChargersOnline - Eaton Nose Cone Service Kit (Torsion Coupler)
SuperChargersOnline - Eaton Nose Cone Service Kit (aftermarket)
Rolling Performance - Replacement coupler (aftermarket)
ZZP SUPERCHARGER COUPLER - ZZPerformance
DIY Coupler replacement.
SuperChargersOnline - How to replace an Eaton Supercharger Coupler
6) Nose rebuild/replacement
As the nose bearing wear, the normal rattling sound the SC makes will get much louder and more pronounced. It can get pretty bad and indicates that the SC is overdue for at least a nose drive overhaul.
Rolling Performance - Rebuilding your Eaton snout
DIY YouTube Nose rebuild.
7) Inter-cooler cleaning
When you have the SC pulled for the 30K nose oil maintenance, it is also a good idea to clean up any crap/oil accumulation on your inter-cooler core. This will help the SC be more efficient at cooling.
Consider adding an oil catch can to keep the blow-by from collecting on the inter-cooler.
TTC Performance
Conceptual Polymer (I use this one)
Saikou Michi Co.
42 Draft Designs
8) Supercharger rebuilds/service
PSE Superchargers $700 for a fully re-manufactured supercharger. Fully Remanufactured Supercharger
Stiegemeier 795.00 for rebuild, port, balanced, and blue printed. Supercharger Rebuilding & Repair
Magnuson Products $300 for a noise rebuild or little under a grand for a full rebuild including "new" rotor packs.
Above info taken from the xr-undergound forum. XR-Underground - View Single Post - Normal TRD Supercharger Noise??
Jon Bond Performance $725 07-09 FJ CRUISER TRD SUPERCHARGER REMANUFACTURE / REBUILD (Recomended by forum member DocME)
2009 Fj Cruiser silver Auto trans (Fast color):)
installed at 29,000 miles
TRD Supercharger with kit
TRD exhaust
200 miles on SC going on a trip wed will update MPG
TRD Supercharger intake NOT TRD CAI There is a difference neither stock are stock
LOVE THE EXTRA POWER AND SOUND!!!!!
Might want to add regular service and whats involved?
________
Vaporizer television
You guys would get beter performance if you helped that forced induction flow better. I am thinking high flow rate intake, long tube headers, y-pipes or straight dual, and high performance large diameter exhaust.
I'm not unhappy with the performance I get right now. I would love to add a aFe CAI, APR X-One, and NST Overdrive kit, but these would kill my warranty. So it's not going to happen... at least for a while. :)
Pretty sure this system was designed to work without any off that stuff.. I like my warranty and have a sports car and one of these which runs in the 9's.. Notice the Plate.. Oh and why can't a FAT PIG be fast on a Dirt rutted road where a sports car, motorcycle would be really slow.. Why does everyone compare power to speed on pavement? I'll put my FJ or TJ against any Nascar in the desert.
________
_Penelope_
Does the addition of the SC make it "Tactical"? LMAO. I love my SC and what it did for the FJ. Now I have to go dig out the paperwork and post up the info or face "Flaming Troll Syndrome".
It's not that simple. As soon as you open up the exhaust like you've described, you will create issues with building boost pressure in the intake manifold. Not sure about our applications, but on the V8's I've done we'll lose 2-4lbs of boost.
You can offset this by increasing boost pressure, as long as the supercharger,engine and fuel system can handle.
We've run into this problem on the GT500 Mustangs. We installed the 2.6 blower pulley, intake and a proper tune and made 540rwhp. Then added long tube headers and a cat-back, re-tuned and picked up 5 more hp. But we lost 25lb/ft of torque right in the middle of power band.
So we upped the boost some more to compensate by changing out the crank pulley and got back to 15lbs. But intake temps spiked indicating that we had maxed out the blower.
Reactions: Luke G
SC: TRD
Install Mileage: 16,131 (07-27-10)
SC Mileage: 6,577 (02-06-11)
Current Mileage: 22,708 (02-06-11)
Add on CAI: None - stock
Other Options: None - stock exhaust
Performance Info: None - But seat of the pants says :bigthumb:
Issues/Comments: None - But this little pig is just a little faster now
Picture: Looks like the ones posted
I have updated the original post with the start of a "Supercharger Maintenance Guide". Understand that I am not a supercharger expert and am "learning as I do".
[/url][/IMG]
[/url][/IMG]
Installed 11/21/2007
Vehicle Info: '07 silver AT
SC: TRD
Install Mileage: 23,000+/-
SC Mileage: 70,000+
Current Mileage: 98,000
Add on CAI: TRD
Other Options: DT Long tube headers, DT cat eliminating y-pipe, TRD cat-back
Performance Info: See dyno sheet above
Issues/Comments: fj used for hauling 12' tandem trailer, nice to have the power, slight loss of low end torque/ back pressure when new exhaust installed. Still on first SC Belt!
Picture: see above
Vehicle Info: 2007 AT (indicate manual or auto)
SC: TRD
Installation Miles: 20,000 (# of miles on vehicle at installation)
SC Miles: 500 (# of miles on supercharger)
Current Miles:20500
Add on CAI: Stock With Air Raid external air filter
Other options: TRD exhaust (
Haven't had a chance to really use the FJ since SC has been installed. But so far REALLY like the added power!!
We are leaving on a trip to Arizona and SoCal for Spring Break. Plan on wheeling in Joshua Tree and possibly around the Big Bear area. Will report back with performance and gas mileage.
Vehicle Info: 2009 auto
SC: TRD
SC Miles: 23,000
Current Miles: 23,020
CAI: ARB Snorkel
Other options: None
I've been wondering about service of the supercharger for a while now. I'm glad i found this post. As stated in the OP,
"The TRD supercharger is considered a sealed non-serviceable unit with a maintenance free service life of 100,000 miles. As such, your dealer will have no procedures to follow for doing regular maintenance, so you are on your own."
As far changing the nose (snout) oil/ a nose rebuild/replacement, do you know if this can be performed at the dealer? Actually, i don't know if i trust the dealer to do this. Really... how many superchargers do some of these dealers install/service? i'm scheduled this thursday for them to change my s/c belt. i made this appointment with the assumption that it was a warranty item. Hopefully someone that has gone through this will chime in.
ONE MORE THING... the intercooler fluid... does anyone know the type/part number? i happened to let a little escape when i had to relocate my pump when installing my bumper.
Discussion Starter · #13 ·
The coolant for the intercooler is the same as for the radiator. Toyota Super Long Life Coolant, the pink stuff, #00272-SLLC2, ~$26.49 gal.
I was reading over on the taco forum and there are people over there with 200,000 miles and have SC installed. I was happy to read that info.
UPDATE 9/22/2016
SC: TRD
Installation Miles: 400 (# of miles on vehicle at installation)
SC Miles: 66,432 (# of miles on supercharger) UPDATE: 160,000 Miles
Current Miles: 66,832 UPDATE 160,000
CAI: Stock
Other options: Flowmaster 50 Series Update: @ 160,000 miles added a Bob's can oil separator and changed out exhaust to URD CAT back. Much quieter and deeper than the Flowmaster, also the FM had a large crack in the casing. I also added the URD 2.875" pulley, an Aeromotive fuel pump, and Innovative wide band sensor at 95,000 miles. I have 65,000 miles on those enhancements with no issues.
Issues/comments: No issues. Update: At approximately 95,000 miles I heard a noise that sounded like a box of rocks in the snout. I sent it off for a rebuild to Jon Bond Performance. He did a great job, I now have 160,000 miles with no issues.
Picture:
Hey what are the service recs for the SC and intercooler just out of curiosity? I put a belt in my glove box for emergencies where can I get a pulley tensioner tool?
Harbor Freight. ~$20
Shouldn't need a service for 100K miles. Look at it periodically to see if there is any oil seeping from the nose cone. If you see seepage, then you should look at replacing the nose cone and changing the oil. Check your belt often, the first belt that came with the kit lasted me 55K miles. The replacement that I ordered isn't the same belt and doesn't look like it's going to last as long.
Plugs are supposed to last 100K miles, but I think I'll try and replace mine this year regardless. However, be aware that you will have to pull the body of the supercharger to get to the driver's side plugs.
Fluid for the intercooler system should last 100K ~$15/ea. It's the same Toyota Pink radiator coolant fluid. I bought a couple extra gallons to top off the system, but I haven't needed any yet.
Periodically check for leaks. There's not a lot to do, just drive it.
I have the TRD Supercharger though not on my 07 FJ. It's on my 98 Sienna V6 3.0 (originally marketed for the Solara) 1MZ FE engine..
The nose assembly, the twin impellers are serviceable and very easy to do. At 50K miles of service, I rebuild the nose assembly (replaced the coupler/changed the oil) using the TRD repair kit.
The weakest part of the supercharger is the coupler which is made of hard plastic. When you start to hear the ratlling noise at the nose area, the coupler need to be changed.
The (dirty) twin impellers were removed from the main body;
After a thorough cleaning;
Pictures of the inside chamber of the TRD supercharger where the air compression by the twin impellers happens.
Before;
After it was cleaned;
The shafts of the twin impellers uses a special "blue" grease - high temp and will not liquify.
My Sienna's engine bay;
Before;
Sweet Siena MOD you have to be able to turns some heads when it takes off. Thanks for the pics and info great POST!!
Thats freaking hilarious! A supercharged Sienna...wow. I'm hoping TRD puts out a SC for the 2010 model so I can join this club...with the bigger tires this thing is kind of a dog...haha
1 - 20 of 260 Posts
