1 - 9 of 9 Posts
Ok, I have my first real problem with my FJ. I have been hearing a pop pulling out my driveway on the driver side. I got underneath it today and saw that both the driver and passenger side of the sway-bar is rubbing against my coil. The driver side is the worst it has started to wear a flat spot. Everything seems nice and tight. I have attached a pic. You can see where both it is rubbing against the coil. How do I fix this? I have a 3 inch toytec 2.5 coilover with spc ucas.
I had the same issue with Radflo 2.0’s. They sell a swaybar relocation kit which moves it forward about an inch. I bought mine from Radflo, but I’m sure others sell the kit as well.
Russ
2011 FJ
Russ
2011 FJ
Thank you for the advice. I also have the sway-bar relocation kit. I should of mentioned that in the post above.
If all it is is a piece of metal with two holes in it you could probly make your own with a drill press or hand drill :)
You’re welcome, good luck with the fix. I’m sure somebody is going to suggest removing the swaybar..
Yes that person should be along shortly.
G'day,
Thats not normal at all.... should clear the CO..especially with a relocation bracket fitted.
I can suggest two possible fixes....
1. rotate the CO so the bottom coil lip is on the other side ( might even need to swap CO's ..left n right sides ...not that CO's are generally left n right specific )
2. use a longer sway bar link...to lower the SB end.... the SB should be as horizontal as possible - with your lift and using standard OE SB links its probably pitched up / pulled up ..towards the CO more than normal.
Cheers
Baz
:blueblob:
Discussion Starter #9
G'day,
Cheers
Baz
:blueblob:
I was able to rotate the coil 90 degrees and no more problem. Thanks for the easy fix.
1 - 9 of 9 Posts
