1 - 5 of 5 Posts
First off, my hand is too d*** big to get in the little hole where the nuts are located. Well, actually the first problem I had would be the cargo hook.
The screw that holds it on stripped out on my first attempt...with a screwdriver. This prevented me from removing the side cover. So I used a glove to protect my arm from the plastic.
After successfully removing the nuts things weren't too bad or so I thought...the little plastic devices that hold the lights are quite impossible to get back in.
After about an hour of struggling I finally got everything back into place
Read Only
You could've used a socket...just saying
I had the same problem, stripped w/ a screwdriver, socket with extension made the difference and took the thing off.
Wow, I feel like an idiot. I was so upset yesterday when I changed it that I didn't realize I could do that.
My hand was too big to fit in the access panel too. I called the wife and it was a wrap. :)
1 - 5 of 5 Posts
