21 - 23 of 23 Posts
Personally, I think things like this should be handled between the customer and vendor. If a resolution is not handled offline then take it online. Obviously Jason stepped up to the plate and promptly replied to an email to take care of this issue.
Jason...I got your e-mail reply back to me tonight and appreciate your prompt response and attention to this matter...Thank you for your offers to make things right on the passenger side slider, that is a testament to your excellent customer service and the fact that you care about your customers...I purchased some Rustoleum Flat Black Textured Spray paint and after hitting the affected areas with some 80-grit sand-paper and two coats of paint they look fine...they're sliders and know they will get dinged up down the road...the packaging didn't cause this to happen and I understand keeping costs down on packaging/freight, the welds seem fine, no complaints there. Prep prior to powder coating seems to be the key to a durable finished product...
Clean
Rinse
Etch
Rinse
Grain Refine
Zinc Phosphate
Rinse
Acidulated Rinse
Thanks--
Actually they sand blast all our products before coating. The problem as someone else has pointed out is any small holes (nothing you can see) will let hot gasses out when the powder coating is baked on. The problem is you don't see these till after the powder coating is applied. I guess this is the only powder coating that does this. We could switch to a gloss black color to avoid this. But we and I believe our customers really like the wrinkle finish color.
My apologies. The welds in the pic above look magnificent. Admittedly, welding on tube material is difficult and it is tough to maintain consistent speed to prevent occasional buildup. Based on my experiences with welding and powder coating, there is probably a tiny hole in the weld right where that bubble formed in the OP's powder coat. When the part was heated to bond the powdercoat, it caused the gases inside the tube to expand and push out through the hole thus creating the bubble in the coating.
Yes we take allot of pride in our welding. Where allot of products out there are robot welded (like the factory frames) or job shop welded where time is money, and they just turn up the heat really high and run a straight line. Our welding is all done in house.
The normal procedure is to either grind down the area that is affected by the bubble, re-weld it and have it re-powder coated. If it's not a bad we will do what the OP did and sand and spray with some wrinkle finish paint.
No comment...ok...small comment.
Paint to fit. Never been a fan.
BTW, what is that a picture of with the dimple dies?
Carpet is a great idea. Short of mounting them to a board and trucking, that sounds like a great idea. I'll bet truck freight on a set of sliders approaches $100 though.
That is a rear 05-10 Tacoma bumper. Those welds are not even that good but it's what I had ready to post.
Those are not welds to brag about!
seriously? youre gonna post that about one of the best Toyota aftermarket offroad accessory manufacturers out there? hope you have some threads posted up which display your welding skills.:bigthumb:
agreed, ive made this mistake before too. its easy to get heated and rant when it would have been more professional for the OP to contact Jason and wait for a response. if he said to bad then its ranting time!:lol:
21 - 23 of 23 Posts
