1 - 20 of 38 Posts
4-Corners Moderator
Well after seeing this was in much need of an update I decided to throw together this skid plate comparison!
Click here to read the original full thread: https://www.fjcruiserforums.com/forums/4x4-off-road-tech/15359-complete-skid-plates-comparison.html
Below are all the currently available skid plates and armor protection for our FJ Cruisers. Please check with manufacturers and vendors for latest pricing and availability as they are frequently subject to change.
Click on manufacturer name to go to their website. Feel free to post discussions in this thread about skid plates, ask questions, post your own photos, etc. Enjoy!
ARB
Skid Plate Options & Price:
Front & Transmission Skid Plates - $441
Rock Slider Skid Plates - $154
Construction: Pressed and Folded 3mm Steel
Finish: ???
Notes: Skid plates also compatible with 2010+ Toyota 4Runners and Toyota Prado 120 & 150 Series. The rock slider skids mount to the bottom side of ARB's rock sliders (part #4420100 ).
_____________________
ASFIR 4x4
Front Skid (07 - 09) - $244.02 - 11.5 kg
Front Skid (10 - 14) - $291.03 - 12 kg
Gear Skid (07 - 09) - $132.60 - 5.5 kg
Gear Skid (10 - 14) - $129.60 - 5 kg
Fuel/Transfer Skid - $374.70 - 20 kg
Exhaust Skid - $126.70 - 2 kg
Rear Diff skid - $173.55 - 5 kg
Construction: 1/4" 5052 aluminum
Finish: unfinished
Notes: Unsure on the skid plate finish or weights and their website is pretty confusing as there are random compatibility dates thrown around (like 06-09, 10-11, 06-12, 11-12, etc.) so I just tried to make my best guess as to what they really meant. Since they are out of the US their shipping rates are pretty high as well.
Boz Tec
Skid Plate Options, Price, & Weight:
Rear Diff Skid Plate - $386 - ??? lbs
Construction: "Built from 1/4" steel, welded inside and out with a 3/4" steel cradle. Two saddle connections are form fitted to the axle tubes, secured with 1/2" U bolts and protect the axle housing out to the spring buckets providing optimal coverage of the rear differential and e-locker as well."
Finish: primer powder coat
Notes: For FJ, Tacoma, or 4Runners
BudBuilt
Front Skid - $289 - 31 lbs
Mid Skid - $249 - 45 lbs
T-Case Skid - $229 - 43 lbs
Crossmember - $149 - 15 lbs
4-Piece Combo (All 4 Above in Regular or Light Options) - $725
Gas Tank Skid - $239 - 45 lbs
Beefy Gas Tank Skid - $379 - 62 lbs
5-Piece Combo (4-Piece combo + gas tank skid) - $900
5-Piece Combo w/ Beefy Gas Tank Skid (In regular or Lite Options) - $1,050
Rear Diff Skid - $298 ($50 discount if purchased with combo) - 22 lbs
Front Skid for Rough Country 6" Lifts - $300 - 31 lbs
Mid Skid for Rough Country 6" Lifts - $300 - 45 lbs
Stock Bumper Filler Plate - $140 - 25 lbs
ARB Bumper Filler Plate - $150 - 25 lbs
Warrior Bumper Filler Plate - $150 - 25 lbs
Expedition One Bumper Filler Plate - $170 - 25 lbs
Construction: Steel 3/16", Light Steel 1/8", Aluminum 1/4", Stainless Steel 3/16"
Finish: Unfinished, Powdercoat (any color) on 4-Piece Combo +$293, Powdercoat (any color) on 5-Piece Combo +$346, Powdercoat (any color) on 5-Piece Combo w/ Beefy Gas Skid +$384
Notes: Many, many options to choose from. I suggest checking out the website.
FJ Toyman Off Road
Skid Options & Price:
Rear Shock Lower Mount Skids - $125 ($150 for King Shock Guards)
Bolt Bumpers - $17.50
Construction: Steel skids and bolt bumpers are 316 stainless steel
Finish: Powdercoated (Metallic Blue only option for King Shock Skids)
Icon Vehicle Dynamics
Skid Options, Price, weight, build, finish:
Lower Control Arm Skids - $173.20 - 15 lbs - 3/16" laser cut steel - powdercoated black
Rear Lower Shock Mount Shin Guard - $131.20 - 5 lbs - 12 Gauge 304 Stainless Steel - unfinished
Outpost Offroad (OPOR) - Visit MetalTech4x4.com
Skid Options &Price:
Lower Link Front Mount Skid - $69.96
Construction: 3/16" steel
Finish: unfinished
Notes: 100% Bolt on but front tail can be welded to frame for maximum strength
RCI Off Road
Skid Options, Price, Weight:
Front Skid Plate - $220 - 35 lbs (steel) or 18 lbs (aluminum)
Transmission Skid Plate - $165 - 28 lbs (steel) or 14 lbs (aluminum)
Transfer Case Skid Plate - $235 - 33 lbs (steel) or 22 lbs (aluminum)
Fuel Tank Skid Plate - $195 - 30 lbs (steel) or 20 lbs (aluminum)
Lower Control Arm Skids - $115 - 16 lbs (steel) or 8 lbs (aluminum)
Rear Differential Skid - $295 - 18 lbs (steel)
Lower Link Front Skids - $130 - 8 lbs (steel)
2010+ OEM Bumper Filler Plate - $65 - 4 lbs (steel)
TRD Integration Plate - $200 - 10 lbs (aluminum)
Construction: 3/16" Steel or 1/4" 5052 Aluminum
Finish: Unfinished or Black Satin Powdercoat
Notes: Filler Plate for OEM Bumper only for 2010+ FJs and the TRD Integration Plate is basically a Transmission Skid Plate but cut in such a way so owners can utilize their TRD skid plate like what came on the Trail Teams Ultimate Edition or TRD Pro vehicles.
______________________
RESZ Fab
Front Heavy Duty Skid Plate 07-09 FJs: $349.95
Front Heavy Duty Skid Plate 10+ FJs: 389.95
Construction:
Replaces 2 front factory skid plates
CNC laser cut and formed out of 3/16″ steel
Heavily braced to take a beating on the rocks
6 recessed mounting points
No exposed bolt heads
2010+ comes with removable panel for easy access to oil filter
Finish: Bare Metal Only
Notes: New Run This Fall!
___________________
Ricochet Off-Road
Heavy Duty Front Bash Plate & Engine Skid - $389
Transmission Skid Plate - $129
Transfer Case Skid Plate - $109
Fuel Tank Skid Plate - $249
Lower Control Arm Skids - $129
Cross Member - $99
Cat Tube Rock Blocks - $29
Combo w/ Everything Above + Free Gift - $995
Expedition One Bumper Filler Plate - $60
ARB Bumper Filler Plate - $99
Rear Bumper Skid Plate - $99
Construction: 1/4" 5052 H-32 Aluminum
Finish: Natural Aluminum Finish or Anodized Black, Red, Blue, Orange, Gold, Gun Metal, or Natural Brushed
Notes: Anodization can be done to all skid plates or when in a combo kit can be selected for only the front bash plate and lower control arm skids or all skids.
___________________
ShrockWorks
Skid Options, Price, & Weight:
Engine Skid - $309 - 42 lbs
Transmission Skid Plate - $299 - 28 lbs
Transfer Case Skid Plate - $279 - 29 lbs
Fuel Tank Skid Plate - $349 - 56 lbs
Cross Member - $50 - ??? lbs
Package of 5 - $1,161 (bare) or $1,321 (black powder coat)
Finish: bare steel or black powder coat
Notes: $75 in savings when 5-piece combo package is purchased
Skid Mark 4x4
Hitch Skid Plate - $154.95 - 16 lbs
Construction: 1/4" Steel
Finish: unpainted or powdercoated red or black (+$10)
Notes: Fits in 2x2" hitch receivers.
_______________________
Total Chaos
OEM Lower Control Arm Skids - $131.30
Long Travel LCA +2" Skids - $117.64
Long Travel LCA +3.5" Skids - $117.64
Lower Link Front Mount Skids - $105.03
Construction: Steel
Finish: Unfinished
Notes: Long Travel lower control arm +2" and +3.5" skids only compatible with Total Chaos long travel LCAs. Lower Link Mount Skids only compatible with OEM or Total Chaos lower links.
Toyota/TRD
Front TRD Skid Plate - $275
Construction: 1/4" Aluminum
Finish: Powdercoated Silver
Notes: Only compatible with 2010+ FJ Cruisers. Integrated TRD logo. See RCI Off Road Skid Plates for compatible skid plate system that integrates this TRD skid plate
Trail-Gear
Skid Options, Price, & Construction:
Front Bumper Skid - $109.43 - 3/16" Steel
Transfer Case Skid - $219.96 - 3/16" Steel and 1.5" .120 steel tubing
Rear Diff Skid - $43.11 - 1/4" A36 Steel
Finish: Unfinished
Notes: Front bumper skid only works on Trail-Gear Front Bumpers but is designed to fit with the addition of Line-X or Rhino Liner bed liners. Rear Diff skid requires being welded on.
Trailworx Fabrication - Visit RedDirtOffroad.com
Lower Link Front Mount Armor - $175
Construction: Steel
Finish: Unfinished
Notes:
4-Corners Moderator
I Have a V-8!! Moderator
Good job.
fka BLACK HAWK
"BozTec Rear Diff Skid Plate – Update!
Friday, May 12, 2017
Attention BozTec fans! Effective immediately, production of our BozTec rear differential skid plate will pause unitl further notice. *Check back for any updates . We apologize for any inconvenience this may cause. Get out and wheel!"
4-Corners Moderator
Thank you for taking the time to put such a complete post together - much appreciated!
I was looking to add the Ricochet products to my 2014, but...have a ToyTec 3" lift with a 1" Diff Drop.
The folks at Ricochet say that their skids will not fit because of it.
Has anyone had fitment luck of under body armor with a front differential being lowered?
Thank you!
Thanks Hayden, a full set will be my next big purchase to be trail ready. This info will be very helpful.
Hopefully some members will post which brand they went with and the pro's and con's of each.
4-Corners Moderator
Discussion Starter #13
4-Corners Moderator
Discussion Starter #14
Looks like All-Pro has said goodbye not only to the FJ Cruiser bumpers but also now the skid plates. Posting these here for documentation purposes.
All-Pro Offroad
Availability: Out of production
Front IFS Skid Plate - $269 - 54 lbs
Transmission Skid Plate - $99 - 12 lbs
Transfer Case Skid Plate - $389 - 42 lbs
Lower Link Front Mount Skids - $129 - 7 lbs
Lower Link Rear Mount Skids - $99 - 5 lbs
Construction: Steel (Aluminum Available for Front IFS Skid Plate +$90)
Finish: Black powdercoat available (Standard on Link Mount Skids, +$30 for Transmission Skid, +$50 each for Front and Transfer Case Skids)
Notes: Transmission Skid requires Front IFS Skid Plate
2007 Toyota FJ Cruiser
Just ordered a front skid plate for my 07 FJ from ASFIR (located in Israel??) for $263, including shipping. Most of the links and info above are out of date of course, but this is a great list to work from and get info / ideas. Thanks for putting it together!!
Just received my ASFIR front skid plate ... in 12 days ... all the way from Israel ... during a worldwide pandemic ... CRAZY!!!
This thing is super beefy, 1/4in thick aluminum. There are big bend reliefs at the base of every cut and all of the edges are dressed nicely and finger friendly. The bottom surface is nicely polished to a shiny bare aluminum finish while the top surface is raw and untouched. The bolt clearance holes are slotted and the port access openings look like they will provide plenty of tool and hand access.
All in all I'm really impressed with the company, the shipping and the product. Installation will hopefully happen this weekend after I finish up the transmission and power steering hard line replacement and cleanup.
I installed the ASFIR skid plate tonight. If it wasn't for the absolute undercarriage rust bucket that is a typical northeastern FJ I think it would have been about a 30 minute job. Max!
Instead, 1 of the bolts holding the rear OEM skid plate stripped on me and required many tools and curse words to settle out. Then I realized that the 2 front bolts are reusing the bolt holes of the long gone OEM front skid plate. Well .... those bolts are still rusted in place with the heads broken off.
Bottom line is that I only have 4 of the 6 bolts holding the skid plate on. It looks great and is really sturdy. Fantastic fit!! I will have to figure something out for the 2 front bolts at some point in the near future.
I would definitely recommend the ASFIR skid plate for price, lead time, customer service, fit and function.
B-Man.
If you get a chance post a couple pics of the asfir skid installed.
Think I am going to pull the trigger on the front and transmission skids. Wanted aluminum as it is lighter a better fit for me in the Midwest.
Also want it to match up to existing oem bumper. Not many options that do. Much easier to cut off if adding an aftermarket bumper than weld to. Especially with aluminum.
Scoured the internets. Liked the look of the Rasta4x4, but they are either out of business or forbidden from selling in the US.
Like the look of the Jaos, but is flimsy bling crap and $$$$. Same for TRD only don't like the look of it. Neither really protect much at all. Only bolt over existing and mine are garbage.
Thanks. Glad to hear you like them.
1 - 20 of 38 Posts
