1 - 3 of 3 Posts
How does the 4 pin wiring connector thing hook up with the skid plate? I can't figure out where it's supposed to go or how it's supposed to hang. The instructions I have don't apply to the Trail Teams/skid plate edition. The kit came with a metal piece that the pin connector is supposed to hook to. There is a hole in the skid, and I figure it goes through there. If you have a pic showing how yours is hooked up I'd really appreciate seeing it. I am just about doing hooking it all up, but I have to hook the connector up and put the skid back on to be done.
By the way..... thanks Toyota for giving me some pre-stripped threads on the bumper/frame where I hook in the hitch. 5 stores and 3 hours later I had to redo the threads. For those who run into this later, you will need a 12 mm 1.25 thread tap in order to clean it out so the bolts will go in right.
I didnt mount mine to the skid. I just shoved it up in the opening and will pull it down when I need it. I found that mounted on the skid the 4 pin hung down too far and was too far from the hitch to connect the trailer 4 pin.
1 - 3 of 3 Posts
